Old 01-07-2018, 12:31 PM   #1
NoNeck
NoNeck's Avatar
Front Coil Springs Recommendation
We have the C10 almost finished but are looking for insight on possibly changing the front coils. After bolting everything together the front is a little lower than we can live with without inner fender modifications.
The truck has the '73-'87 crossmember swap with McGaughy's 2.5" drop spindles and stock small block coil springs with one coil removed.
During the build we installed a Big Block, Vintage Air System, Vacuum Canister, Fan Relay Modules and Coolant Overflow Tank. Of course, all of these components added weight to the nose.
Our thoughts are:
Stock Small Block Springs (no coils removed)
Belltech 2" Lowering Springs (higher spring rate)
Stock Big Block Springs (one coil removed)
Air Bags
Thanks,
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 01-07-2018, 12:47 PM   #2
roboticjunky
Re: Front Coil Springs Recommendation
What about coil spring spacers?
https://www.summitracing.com/search/...spring-spacers
roboticjunky is offline   Reply With Quote
Old 01-07-2018, 04:13 PM   #3
FRCvette
Would love to see more pics of your truck. I love the anniversary c/10.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 01-07-2018, 04:23 PM   #4
6T7 C10
First of all beautiful truck. Maybe a set of new 3/4 springs with one coil removed should do the trick.
6T7 C10 is offline   Reply With Quote
Old 01-08-2018, 12:49 PM   #5
Keystone_Hate
I would go with stock small block springs.
Keystone_Hate is offline   Reply With Quote
Old 01-08-2018, 01:05 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
It's all going to be a guess or trial and error unless you just add a set of Belltech spring spacers.
Bags would be great because they give you adjustability.
Keith
Convert to disc brakes.
Old 01-08-2018, 01:45 PM   #7
leddzepp
Moderator
leddzepp's Avatar
I’d start with this. It “should” bring up the front about 2”.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
