![]() Join Date: Jun 2014
Tilt Column Light Green Filter
Ok - tying up loose ends on my final assembly and had an "unfortunate" incident with the small green cover (filter) for the light indicator. GM part number377994. May have been superceded by 3772254. Has anyone found a source for these? I would think that all GM products of that era that had tilt columns would have used this P/N but not getting any hits on Google. Anyone have any success finding these?
TiA, Randy |
Re: Tilt Column Light Green Filter
TTT - has anybody figured out an alternative solution? Maybe paint the bulb green?...
Thanks, Randy |
I found a packet of green filters at PepBoys, but I'm sure you can find them in any AP store that carries lighting accessories. I haven't got around to putting one on yet, so I don't know how it'll work
any chance you could post a part number - manufacturer - UPC code? Anything to help chase them down would be greatly appreciated.
TIA, Randy |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks Andy - I have that photo and the part number for the filter. Can't find the green filter....
B/R, Randy |
Autometer has a green light cover that might work #3215
Beadblaster - Great info!!! On order, will post on how they work out. There was another brand for a similar item on Amazon also. Ordered some of those also to have options.
B/R, Randy |
Old member
Old member
Oh snap didn't know the picture was that big! sorry!
So with the help of the forum members I had success with the little green light "condoms".
![]() Here's what worked for me. I ordered a package of the AutoMeter green light boots (P/N 3215) as pictured in the above responses as well as a package of the Memotronics green boots (P/N BOOT-G-LARGE) to see which ones would fit better. Results were the Autometer bulb covers have a lip around the base of the covers that prevent the bulb cover when installed on the metal bulb housing from fitting into the column. You could take a razor blade and trim the lip off the bulb cover once installed over the housing. The Memotronics don't have the lip and work great! They fit very well (lube with windex to slide onto the bulb housing) and are the right shade of green to match very closely to the instrument cluster lights. They come in a package of 5 which is good because they are very thin. I tore one on the first attempt. Another trick on the insertion/removal of the actual bulb (P/N 1445) as it's very hard to get to with these old fat fingers is t use a small piece (2-3") of rubber hose just slightly smaller than the bulb diameter to rotate the bulb to insert/remove. Rotate very slightly clockwise to install, Opposite to remove. Thanks to all for the help! Maybe this will help someone else. Randy |
Good info! What website did you order those Memotronics boots from?
Thanks! |
#13 |
Amazon has both of the ones I discussed...
B/R, Randy |
#14 |
![]() Join Date: Jul 2001
Subscribed to this. Good info there, Randy. Thanks for doing the "leg" work in finding what will work.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#15 |
So being fairly new to the forum and learning so much from the "old Timers" I just want to contribute when and where I can. Working on some other stuff too. Why are the aftermarket stainless windshield trims crap? I've got a set of aftermarket trim placed next to a set of OEM. The aftermarket trim is not formed correctly! The top long piece that goes all the way across the windshield is the wrong curvature and there is no "flex"! More on that in another thread...
Which aftermarket radio antennae fit our trucks - not many but I just received a new one from a vendor last night that looks pretty darn good. Will report out on that after I do a "fit test" on my truck this weekend. Results in a new thread... Front aftermarket fenders are CRAP. I learned the hard way, cost me a bunch of $$$... New Thread coming... Aftermarket tachs with HEI distributors won't work. Oh yes they (some) will! New thread... I really need to learn how to post pics so you guys can see what I'm talking about on all the above. Anyway, just want to pass on lessons learned where I can. Best Regards, Randy |
