Old 01-07-2018, 02:56 PM   #1
randy.powell
Best Fitting Replacement Fixed Mast Radio Antenna
Searched extensively on the forum but all the data is old. Looking for a source for a replacement antenna with a fixed length mast (for FM) antenna that fits the original cowl mounting location for my 71 Cheyenne Super. Anyone buy one recently that fits properly? Vendor / part number would be great.
Thanks,
Randy
randy.powell is offline   Reply With Quote
Old 01-07-2018, 04:47 PM   #2
jojomiamia
Re: Best Fitting Replacement Fixed Mast Radio Antenna
I bought summit, fits well on my 72 C20
jojomiamia is offline   Reply With Quote
Old 01-07-2018, 05:51 PM   #3
72_K10_Vegas
72_K10_Vegas's Avatar
Subscribed
72 K10
72_K10_Vegas is offline   Reply With Quote
Old 01-08-2018, 07:18 AM   #4
randy.powell
Anybody?
Old 01-08-2018, 08:28 AM   #5
dennislbrooks
dennislbrooks's Avatar
I am going to try the fixed mast off my 2006 to see if it makes a diff from my stock type adjustable mast. If it does I will purchase a stainless 31" whip. I have adapter threads coming to try the 2006. Will see. Also down in audio I modified a non-67-72 - newer - AM/FM delco into my 67.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 01-08-2018, 01:20 PM   #6
dell72
I went to the local Autozone parts store and bought a stainless steel antenna. It's probably not 100% OEM in appearance but it looks era correct.
dell72 is offline   Reply With Quote
Old 01-08-2018, 06:26 PM   #7
FirstOwner69
FirstOwner69's Avatar
I bought one 3 or 4 years ago that fits as well as the original telescoping mast antenna on my '69. I got it from an eBay seller in St. George, Utah. Problem is, I'm no where near my records and am not sure of who made it, but it may have been Counterparts. Below are a couple pictures. One shows the base of my original compared to the installed reproduction. The other is a zoomed in version of the only picture I can find with the antenna clearly visible. I'm fairly certain the original fixed mast AM/FM antennas used a different base if that's important to you. The antenna in this link appears to look the same as mine. https://www.ebay.com/itm/1967-1972-C...RZ6h-c&vxp=mtr
Prior to buying mine, I had converted my original to a fixed mast. If interested, I can describe how I did it. Very simple and something to consider if you have an original in good shape.
FirstOwner69 is offline   Reply With Quote
Old 01-08-2018, 10:51 PM   #8
bMr
Well it isn't a fixed mast but last weekend I installed this telescoping antenna from Classic Industries. The angle was right on and had the proper keyway to fit the notch in the cowl.
https://www.classicindustries.com/pr...ts/cx1414.html
bMr is offline   Reply With Quote
Old 01-09-2018, 08:02 AM   #9
randy.powell
Great help all y'all! Ordered a fixed mast antenna yesterday from Classic Industries. Will follow up on this thread as to if it's a "keeper" or a POS.
Randy
Old 01-09-2018, 09:05 AM   #10
B Myers
B Myers's Avatar
I'm in, going to install a reproduction radio and I was considering the inside antenna that the radio company offers to replace the original. I'd rather have the original replacement though if it works.
B Myers is offline   Reply With Quote
Old 01-10-2018, 04:37 PM   #11
dennislbrooks
Info ------- If you have an oem extension mast or a LMC aftermarket repop the thread into the base should be 1/4 x20. I plan on cutting the threads on a removal -- many out there. The mast I am using has a blank extension before a smaller finer thread. Cutting threads on stainless with tool steel dies is not easy but keep lubed with trans fluid and work it back and forth.
