11-02-2003, 01:47 PM | #1 |
79 blazer turning over slow
After my blazer is running for awhile when I turn it off and try to start it back up it turns over real slow sometimes I have to wait a extra 10 to 15 minutes to start it back up any thoughts to what it might be.
11-02-2003, 04:34 PM | #2 |
From a article I read
So your Chevy is experiencing hot start problems. You've ruled out the starter as the culprit, or replaced it entirely, you've checked all the connections but you still experience those no start conditions. What to do next? Add a Ford Starter Solenoid to your Chevy of course!
It worked for chevy, it can work for you. Chevrolet offered a remote solenoid for their motorhomes for the very same reason. Why? Because when wire gets warmer, its resitance goes up. Which means, when things are toasty warm your starter is not getting enough juice to activate the (on starter) solenoid from the original "start" wire. The wire is essentially acting like a ballast resistor. As well, the starter heat soak creates its own set of unique problems. Wiring in a Ford Solenoid 'My Way' will alleviate the wire voltage drop problem by giving the starter mounted solenoid full battery potential when you turn the key. What you need to do; Get a Ford starter solenoid of course. These units ground through the bracket. For fool proof grounds run a well grounded wire to one of the screws you use to secure the solenoid to the firewall. If you are adament about not having any ford parts on your General Motors product, simply visit your favorite AC Delco parts house and purchase p/n U939. You can use just about any ford starter solenoid, later model cars came with a stubby unit with all the terminals opposite the mounting flange, such as found on 1987 and newer Ford Crown Vics and Mercury Grand Marquis. (until 1996 or so when Ford went to the starter mounted solenoid like the Chevy your converting. Go figure.) Relocate ALL the wires that are currently connected to the BAT terminal on your starter (the large terminal) to the 'hot' side of the ford solenoid (thats the side connected to the battery, typically the large post to the left on the ford solenoid) This will allow you to relocate the wires away from the (hot) engine block Relocate the 'start' wire on the starter solenoid (small terminal closest to the engine) to the 'S' terminal on the ford solenoid (if using the relay as pictured above, the S terminal is usually the one on the left) IF you are still using a points ignition system relocate the bypass wire (small terminal furthest from engine block) to the 'I' terminal on the ford solenoid. Run a new heavy guage wire from the HOT side of the ford solenoid to the BAT terminal on the starter (the large terminal). Yes, thats correct, the bat terminal will be hot at all times like the original hookup Now, run at least an 8 guage wire from the cold side of the ford solenoid to the 'S' terminal on the starter. (Thats the large lug on the right of the ford solenoid to the small terminal closest to the engine block on the starter). becuase many of the no start problems are related to excess voltage drop on the original 'start' wire and a hot starter, this method of wiring allows full battery voltage to reach the starter solenoid. the ford solenoid does not require anywhere near as much current to activate, therefore the voltage drop problem is essential irrelavent. Thats about all there is to adding a remote solenoid to your GM. A couple advantages to having the ford solenoid, -its a lot easier to "start the car with a screwdriver" since all the terminals are up on the firewall. -my favorite, disconnect the wires that run to the starter from the ford solenoid and you only need to drop out the starter from the bottom, no fiddling around while lying under the car to disconnect the wiring from the starter, especially if you have header tubes cleaverly designed to be in the way. Last edited by Nvbowtie; 11-02-2003 at 04:37 PM. |
11-02-2003, 08:16 PM | #3 |
Have you checked the timing? I have had the timing off befor and had the same problems. A few adjustments and it starts fine.
Chuck '85 Chevy Silverado 4X4 '91 Chevy 4X4 Suburban http://www.cardomain.com/memberpage/545941 |
11-03-2003, 01:12 AM | #4 |
I have had the timing adjusted and it still does the same thing I think maybe I will try to insulate the starter and see what happens because I have headers on the truck
11-03-2003, 09:42 AM | #5 |
Insert witty comment here
Its been my experience that that once you heat soak your starter its gonna die sooner or later. I had the same prob with my 79. Fixed the heat soakwith a heat shield and everything worked fine for a while. but the starter slowly got worse. Just so your aware it might happen.
I changed the starter and bingo! No more probs.. |
11-03-2003, 09:17 PM | #6 |
Hey 74Pumpkin when you changed your starter did you put the heat shield back on or leave it off
11-27-2003, 04:25 AM | #7 |
went with a ford solenoid
used the ford solenoid method and everything works great thanks for the info NVBOWTIE
11-27-2003, 05:17 PM | #8 | |
Re: went with a ford solenoid
11-27-2003, 11:25 PM | #9 |
5-7 dropped 87 CC Dually
Upgrade your cables too. I used audio amp cable 4ga for my starter and ground cables. 8ga from alt. to batt.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
11-28-2003, 02:45 AM | #10 |
put new cables except for the neg side probably should change that one also. thanks
