Old 01-07-2018, 10:24 PM   #1
hvacfatboy
Blazer bed cross sill
Does anyone have or know where i can get the bed floor cross sill that runs at the back of the rear wheel tubs and is recessed where it mounts to the frame.
hvacfatboy is offline   Reply With Quote
Old 01-08-2018, 08:36 AM   #2
1rippen6
Re: Blazer bed cross sill
The last blazer I just list all the cross sills appear to be in good condition I can check it out and get pictures if so. Let me know if that's something you would be interested in.
1rippen6 is online now   Reply With Quote
Old 01-08-2018, 10:22 PM   #3
hvacfatboy
please if you dont mind and thank you
Old 01-08-2018, 10:36 PM   #4
hemi43
hemi43's Avatar
That part is not available for the Blazer. I purchased one to fit the pickup and modified it. Worked perfect !
http://www.billstruckshop.com/Catalo...2_Jan_2017.pdf
Page 104
hemi43 is offline   Reply With Quote
Old 01-08-2018, 11:34 PM   #5
1rippen6
Its on the lift I will get some pictures tomorrow after work.
Old 01-09-2018, 11:40 PM   #6
1rippen6
pics
Old 01-09-2018, 11:43 PM   #7
1rippen6
more pics
Old 01-10-2018, 01:22 PM   #8
hvacfatboy
That looks to far gone to bother with thanks for looking
Old 01-10-2018, 01:24 PM   #9
hvacfatboy
hemi43 how much did you have to cut out of the truck cross sill to make it work on a 2wd blazer. Thanks for info
Old 01-10-2018, 05:48 PM   #10
hemi43
hemi43's Avatar
I can't remember, all I know is that it will work. Here's the only pictures I could find.
Old 01-10-2018, 08:59 PM   #11
jaros44sr
jaros44sr's Avatar
I've had this piece laying around forever, guess it served a purpose. I did the s[url=https://flic.kr/p/FexDg9]20180110_194838ame thing Hemi did, so I guess I cut off each end about 11"
sorry, been drinking for awhile, my typing is slurrrrrred
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-11-2018, 02:08 PM   #12
K5_Knox
Hemi43, what did you use to finish the undercoat? I am debating between an epoxy primer, POR15, or open to suggestions. I have little to no surface rust.
K5_Knox is offline   Reply With Quote
Old 01-18-2018, 07:56 PM   #13
69-72
69-72's Avatar
You could always get one bent up at your local sheet metal working place.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 01-18-2018, 08:28 PM   #14
hvacfatboy
does anyone have the measurements on this cross sill it will help in having one made. thanks
Old 01-18-2018, 08:48 PM   #15
hemi43
hemi43's Avatar
Don't use POR15 !! Great product over rusted steel, but that's about it. Some say they've had luck over sandblasted new steel, but I still wont use it. I used it once years ago on a Camaro trunk floor pan I installed, and I had major adhesion problems. The other issue is where it did stick, we couldn't get it off.
Over bare metal I only use epoxy. The underside of my truck was sanblasted, sprayed with epoxy, then top coated with a satin urethane black from KBS coatings. This was a real nice product to use, and is very durable. The top coat is sprayed wet on wet so there's perfect adhesion between the two products and no sanding in between.
https://www.kbs-coatings.com/KBS-Maxx.html
Old 01-21-2018, 04:16 PM   #16
richard2717
Equal opportunity joke ofender
richard2717's Avatar
HVAC
I have a mint 71' floor hanging here on the wall. If the cross member you are talking about, is the one I have white arrow on, there is no recess in it where it bolts to the frame. The only one that recesses is the tall one in front of the tubs. The one I have arrowed is just a hat section 1" mounting lip x 1" tall x 1.625" across and 71.75" wide. If you need any other measurements let me know.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 01-21-2018, 09:50 PM   #17
hvacfatboy
thank you for the info on this
