Old 01-08-2018, 02:16 AM   #1
Ptjsk
4x4 versus 4x2 Frame.
I have recently acquired a '69 Chevy (short), Step-side truck.
The truck, as well as the frame are in extremely good condition. Especially as far as rust, or in this case, lack of rust goes.
I would like to make this into a 4wd unit.
My question is, aside from the obvious (leaf springs, axle), are the 4x4 and the 4x2 frames the same?
Thanks,
Pat
Ptjsk is offline   Reply With Quote
Old 01-08-2018, 08:52 AM   #2
Re: 4x4 versus 4x2 Frame.
Thy are not the same but you can bolt the entire 4wd front spring/axle assembly to a 2wd frame. Then you need the crossmember for transfer case from a 4wd or make one. Is your truck coil or leaf rear suspension? The frames are different behind the axle on a coil spring truck. I've never converted a coil spring truck so someone else will have to tell what they did. I have seen one converted leaving the coil rear in place.
Old 01-08-2018, 09:15 AM   #3
Jeff's bowtie's
The frames are the same on coil and leaf trucks they both get wider at the rear of the cab
Jeff's bowtie's is offline   Reply With Quote
Old 01-08-2018, 09:55 AM   #4
dennislbrooks
dennislbrooks's Avatar
I did this for the same reason. The emegency brake stamping in the 2wd frame will need flattened as that is where the front rear 4wd perch resides on a 4wd. I probably have a thread on notching the rear front 4wd perches 1.5 inches on their rear side and adding 1/2" spacer on the rear hanger perch.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 01-08-2018, 10:00 AM   #5
dennislbrooks
There are multiple threads on this and methods including flipping existing 2wd axle and keeping trailing arms ---I did not . Here is one with pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=505589
Old 01-08-2018, 10:32 AM   #6
Ptjsk
Thanks a lot for your responses.
This is good to know, as I would like to keep the frame, yet make it a 4WD.
I'm thinking that probably the best bet is to find a rolling chassis that I could cannibalize while having both frames sitting side by side.
Also, I do have the trailing arm, coil spring rear suspension, which I would change over to leaf springs.
Thanks again,
Pat
