Boxing a SWB frame
Hello, I was just curious if there were any areas that might benefit from boxing on the frame or if it was over kill. Street truck, not big power.
Re: Boxing a SWB frame
You just answered your own question right there. No need, yes overkill.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
Moderator
![]() Join Date: May 2007
Overkill
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Thanks guys. So there aren't any weak areas at all? It doesn't flex at all?
Well sure, it's a pickup so of course it flexes some. Tying the cab and the box together would do more to eliminate flex. But there is little you can do to the frame alone without adding a BUNCH of weight and complexity that would greatly reduce flex. Are you planning to run your truck on a road course?
In addition the frame is freakin' HEAVY (I mean, it's a truck so it should be). The suspension is heavy, huge amounts of unsprung weight, and a solid axle. The best way to carve corners in one of these would be to make a tube frame chassis and wrap the truck sheetmetal around it. They are also tall with a high center of gravity. Even with a lowered truck, the engine still sits a mile above the frame. Not to mention the obvious forward weight bias found in any pickup.
Well I figured there wasn't much point in boxing it. My brother wanted to box it in some of the areas, I don't think the entire thing. I was trying to ask all of the questions really to make sure. Thanks.
Throw some jackstands under it and let it down, you'll see how much it flexes! I'm always surprised and slightly concerned when I see the nose continue to go down several inches after it contacts the jackstands. But as mentioned above, it's an old truck, it's going to flex.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#8 | |
Like others have said, not necessary.
My other vehicle is unmanned.... |
#9 | |
At the body shop.
Only real weak point is the frame rail by the steering box mounts
" That didnt make it any newer " " Dont antique the equipment " |
#11 | |
#12 | |
#13 |
Continuing the thread,
So I should box the whole thing, and how thin of metal can I get away with, and I will be pro streeting my 62 with a full back half
1962 chevy short and wide 2015 z71 1967 SS Chevelle |
#14 |
We are replacing the body bushings with poly urethane from Energy Suspension. And that's pretty much all trucks going down the road because the bed is rigidly mounted and the cab is on bushings.
I'm curious KQQL IT, is there anything that can be done in the area of the steering box mounts? |
