Old 11-02-2003, 02:50 PM   #1
mutant-jimbo
mutant-jimbo's Avatar
shackel flip
i was wondering if anyone uses the shackel flip? ive read alot about it, i was thinking of buying the 4" rear made by offraod design. currently i have blocks in the rear. it looks like the real deal, but i want input from someone who uses it. also i like the way the front flip by hill 4wheel drive looks. its 1" upgrade, but then i would have to find 1" blocks for the rear, ive never even heard of 1" blocks? any input? i can throw in some pictures from the web sites if you dont know what im talking about
"Texas is an outrage when your husband is dead, Texas is an outrage when they pick up his head, Texas is the reason why the presidents dead"-bullet by The Misfits
mutant-jimbo is offline   Reply With Quote
Old 11-02-2003, 07:52 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
PM Yukon Jack.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-03-2003, 02:51 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
I've got the rear shackle flip from Offroad Design and really like it. They also sell a thing called a Zero Rate that will give you 1" lift in the rear and it is center pinned to the spring pack.
You can check out the install of the shackle flip at my website listed in my sig on the install page.
I haven't heard of Hill Four Wheel Drive's flip.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-03-2003, 04:51 PM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I have a 4 inch flip in the rear with 2 inch Blocks and 3 inch Body. Rides pretty decent.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 11-03-2003, 08:32 PM   #5
mutant-jimbo
yukon, check out this site and look under the shackel department
http://hill4wheeldrive.com/
its really more of an extra hanger, but increases the lift by 1", i need to check out that zero rate. thought i read about everything in the offroad site...
also did you catch the 4x4 park link i posted for you?
Old 11-04-2003, 08:44 AM   #6
Mike C
Mike C's Avatar
Yukon has been very happy with his shackle flip, but note that he has a 3/4 ton truck. Most factory blazers sag in the rear BEFORE they are 5 years old! My stock Jimmy springs were just too soft IMO for pulling a trailer, and the rear was lower than the front. I went first with blocks and add-a-leaves, but sag was again an issue, then I bent the perches with the blocks. It now has 4" National HD spring packs.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-04-2003, 11:27 AM   #7
Prerunner1982
Prerunner1982's Avatar
also check over at coloradok5.com they can give you more info on shackle flips.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-04-2003, 08:19 PM   #8
mutant-jimbo
Mike C, you are right, i didnt notice yukon was running a 3/4 ton. i really want to get rid of blocks alltogether.
Prerunner-ck5 is where i found out about both flips, thats a great site, and i hope everyone here checks it out.
Old 11-08-2003, 02:27 PM   #9
drink2mny
drink2mny's Avatar
This is what I did to get 4" without blocks
These are the front perches off the rear springs on a I believe '74 blazer..
I just butted them against my hitch. It gave me perfect angle on the 14 bolt I have under my blazer..
Just drilled 4 holes and welded the edges and center..
Haven't broke yet and I have jumped out of plenty of mud holes
Support The Board
drink2mny is offline   Reply With Quote
Old 11-10-2003, 06:10 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Another person just reminded me on one of the drawbacks of the shackle flip - it moves the rear axle forward a bit in the wheel well. I didn't care cause I knew I was going to go with a flatbed, but might matter to you.
Here's a pic to show you how mine was.
Old 11-10-2003, 08:48 PM   #11
mutant-jimbo
hey jack, doesnt the zero rate kinda solve that? i read the description about it and it says it will move it an 1 1/2" forward or rear
Old 11-11-2003, 12:24 PM   #12
Yukon Jack
Post Whore
Yukon Jack's Avatar
Yep, I believe that will get it back pretty close to where it should be. Jeez, I must be getting old, forgot I mentioned the zero rate earlier in the post :-)
Old 11-11-2003, 09:01 PM   #13
mutant-jimbo
your the one that turned me on to the zero rate, yukon. check your first post...maybe its that kansas sun
Old 12-07-2003, 01:16 AM   #14
ChevyGuyBC
i plan on going with the shackel flip too... but im on limited cash and will be doing it myself.. i do have the nessacary tools welde grinder etc... could someone make a complete list of stuff needed to complete it.. i have 4 inch springs/blocks and just want to get rid of the blocks
ChevyGuyBC is offline   Reply With Quote
Old 12-07-2003, 01:33 AM   #15
mutant-jimbo
my friend did a homemade shakle flip by cutting the bottom out and making the shakle hang down instead of upward. it works real well. no extra stuff needed, unless your hardware is shot
