Old 01-09-2018, 04:34 PM   #1
dfosh
brake line size again
What size brake line comes out of the new proportioning valves? MY brake lines are from drum brakes and have I/4 down to the cross member and tee off to 3/16. The line to the rear is 1/4 inch back to the rear end then tees off to 3/16 across to the drums .My lines are in good shape and I want to use them with my new disc brakes . I haven't got my new master and booster set up . Can I use the lines I have? Thanks for any info.
dfosh is offline   Reply With Quote
Old 01-09-2018, 09:01 PM   #2
sweetk30
sweetk30's Avatar
Re: brake line size again
stock 73-87 trucks use 1/4" feed to valve or tee depending on style . then there dropped to 3/16" to each wheel . and the rear is feed 1/4" to hose at axle then hose end splits it to 3/16"
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-10-2018, 01:31 PM   #3
dfosh
I forgot to mention this is a 68 GMC .
