Where can I find this bolt and washer?
Re: Where can I find this bolt and washer?
Did you try your locally owned parts store? Mine (CarQuest) can get it for you if they don't have it in stock.
I have an O'Reilly auto and a AutoZone, they looked at me cross-eyed when I asked for it. I'll see if I can find it at carquest.
That there be one of them slip yokes them lowered truck guys be talkin 'bout. It don't need no bolt, it slips!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Haha pretty sure it needs a bolt
What does the bolt secure?
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
Maybe a driveshaft shop would have one?
http://www.dennysdriveshaft.com/p59_...r_and_fla.html
Here it is at Denny's, but like everything else, it's not in stock. |
#10 | |
The Older Generation
LockDoc
Fastenal, Grainger, McMaster Carr.
#13 |
Who Changed This?
![]() Join Date: Jan 2013
Nope. That's the join between the front and rear drive shafts where the carrier bearing lives, and needs a bolt. It does not slip, unless you are really unlucky. I don't remember the size, but you can try both 3/8-24 and 7/16-20 (fine thread). One of them should work. Then just get a thick fender washer. Or go to the local pick your part yard and get the "exact" replacement.
#14 | |
#15 |
Had the magic idea to use my tap set to find the right size. It is 1/2x20. I chased the rusty threads and it went right down. Also found the hole is drilled a little wonky. Washer is 1.5" wide.
#16 |
Who Changed This?
1/2". huh, guess I haven't looked at one in a while.
#17 |
