Old 01-10-2018, 04:24 PM   #1
novafrog
novafrog's Avatar
dipstick and oil pan
i have 2000 5.3,broke the lower part of dipstick off it fell into oil pan tried to get it out with magnet didn't do any good can I leave it in oil pan or will it have to come out,if I have drop oil pan will I need new gaskets,thanks guys
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears
70 nova 5.3,350 trans
80 z28 350,350,trans,bought new
03 cat.
06 gmc swb ext cab
novafrog is offline   Reply With Quote
Old 01-10-2018, 05:02 PM   #2
NC_John
NC_John's Avatar
Re: dipstick and oil pan
What is the engine worth? You might be able to get away with it, you might not. If you epoxied a magnet to the bottom of the pan it might catch the dipstick and keep it held. An old engine, I might take my chances. A new/newer one, I'd have to get it out of there so I could sleep at night.
You should not *need* a new oil pan gasket but for the possibilty of an oil leak reusing the old one, I would replace it anyway.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 01-10-2018, 08:10 PM   #3
novafrog
novafrog's Avatar
do I need any sealant,do I have to worry about pan alignment,what is tor.specs.thanks again
03 cat.
06 gmc swb ext cab
Old 01-11-2018, 12:49 AM   #4
DLW
You need to use sealant on all 4 corners where the front and rear covers mount to the block. pan needs to be flush with rear of block. TQ on all but the rear two bolts are 18 ft. lbs. and the rear two are 106 in. lbs.
Google will bring a ton of hits for this, and youtube videos as well.
DLW is offline   Reply With Quote
Old 01-11-2018, 07:54 AM   #5
novafrog
novafrog's Avatar
going after gasket today,thanks dlw
03 cat.
06 gmc swb ext cab
