70 cst 4wd longbox inquiry request
hi guys,
great site, just started looking for a project truck and was looking at a 70 cst 4wd long box, 350cu. cab is repairable, most other panels will need to be replaced. frame and drivetrain is great condition from what I can see, looks to be all there. my goal would be, strip and get frame cleaned up and rolling replacing anything needing replacement. I would over time search for good used body parts or aftermarket (which I don't prefer). asking price is 2k. im out of luck and live in salt country and stuff rusts... does 2k sound ok for pretty much a restorable cab and good drivetrain... |
![]() Join Date: Apr 2013
Re: 70 cst 4wd longbox inquiry request
Is it a K10 or K20
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
All about them K’s
![]() Join Date: Jun 2014
I assume your saying c20 because of the fender badges? If it’s a true 3/4 ton 4x4 it will be known as a K20, however some lower trim level trucks had c20 badges on the fenders. If It’s all there and the cab is repairable and frame is good I’d say yes it’s worth 2,000. Post up some pictures if you can. The real factory K trucks are getting harder and harder to find.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#5 | |
How would you know the difference from.1/2 to to 3/4 . Lugs? Leaves? Rearend? |
All about them K’s
Do you know the vin? The only difference in 3/4 and 1/2 is the springs and axles in a long bed 4x4 frames are the same. It should have leaf springs alll the way around. Pictures can help us figure out what you have.
![]() ![]() Join Date: Sep 2008
1/2 ton K/10 (4x4) has 6 lugs.
3/4 ton K/20 (4x4) has 8 lugs The price sounds fine if it is a true 4x4. Pictures sure help.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#8 | |
He does have a 3/4 ton, maybe that would be better to start with... would a 4wd trans and transfer case from an s10 work and be driveable |
S10 is something like 1/4 ton so it's weak.
70 will have drum brakes and closed knuckle in front, and the TC is likely to no be the more desirable NP205. I suggest you check on all 3 as well as verify whether it's 1/2 or 3/4 ton. I'd move on and wait for a 71 or 72. Even a 1/2 ton will ride like a buckboard, so you need to drive it to see if you want your spine abused everytime you drive it. That said, 2k isn't a bad price. |
#10 | |
All about them K’s
Negative franken. If original 70 front will have drums and an open knuckle. It’s a one year only setup. Tbody- I would not run s-10 stuff. Also there were no 1 ton 4x4s in the 67-72 trucks. 3/4 was king back then.
Could be a Napco
Stan 67 swb BLU MULE posted via flip-fone |
#13 |
6>8 Plugless........
![]() Join Date: Sep 2007
I've had 2 early 1970 K20s that had closed knuckle drum D44s. One of which had a Rockwell tcase in it too. I'm guessing GM used up some 69 production parts on the first 1970s.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#14 |
![]() Join Date: May 2012
Nobody can access your skill set. And it really boils down to that. Repairing a rusty cab is work! Body work is a trade of patience! And a test of patience! The cab and frame is the truck IMHO. Get a straight frame and good cab. Rust repair in large quantities is beyond weekend dickering.
My 2 cents, worth the price paid! ![]()
White K20 |
#15 |
Link broke..trying to post a pic of truck im interested in
#16 |
Looks like to me its a 3/4 ton cst 1970. It has 8 lug wheels and locking hubs.
Im pretty sure ill be getti g it. I thinks its a good foundation to start with. |
