Old 01-11-2018, 03:37 PM   #1
Arl37
White smoke coming out of exhaust when i give it gas
69 C10 with 350 crate. 7000 miles on engine. Edelbrock E Street heads. Edelbrock performer carb.
Changed oil yesterday and today while driving I noticed white smoke coming out of exhaust when I give it gas. Lots of smoke. Oil very clear and clean. Radiator water looks OK. Good oil pressure and engine temp looks fine.
About a month a go I replaced intake manifold gasket to fix oil leak.
What are your ideas on what is causing smoke or how to diagnose.
Arl37 is offline   Reply With Quote
Old 01-11-2018, 03:52 PM   #2
bigmac73
bigmac73's Avatar
Re: White smoke coming out of exhaust when i give it gas
then I would start with the intake gasket, might be seeping a bit. did you pull the plugs and see if they are a greenish tint(antifreeze) ? any excessive moisture or condensation under your valve covers or in the oil fill hole?
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 01-11-2018, 04:10 PM   #3
rockyrivermark
I had the same thing. don't run the engine until you get it fixed.
Buddy installed intake and it leaked water into oil.
oil level was way up. drained and you could see it in a glass jar.
i got new gaskets and followed the edelbrock instructions for the performer intake step by step.
problem solved.
I read not to use silicon on the head size, not sure if that it.
as you prob know anitfreeze will trash the engine bearings.
get it changed before running it again.
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 01-11-2018, 05:20 PM   #4
demian5
demian5's Avatar
How was it before the oil change? White smoke?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-11-2018, 05:35 PM   #5
Boog
laying low
Boog's Avatar
If the truck has an automatic trans pull the rubber hose off the modulator and see if its wet with atf. They can leak and the engine suck atf up to the intake and into the engine.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-11-2018, 06:21 PM   #6
Arl37
does a 700r4 in my 69 c10 with a 350 have a modulator hose
Old 01-11-2018, 06:30 PM   #7
Arl37
I hadn't noticed any smoke before the oil change but it is possible
Old 01-11-2018, 06:31 PM   #8
Arl37
I don't think so. No hoses running from trans to engine
Old 01-11-2018, 06:34 PM   #9
demian5
demian5's Avatar
Pull plugs and post pictures.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-11-2018, 06:35 PM   #10
Bigdav160
Bigdav160's Avatar
More than 50% of your exhaust is water vapor. Does it still smoke after it's warmed up?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-11-2018, 09:49 PM   #11
Arl37
Plugs look oily. One kinda black. The other chocolate but oily. Smoked at first when I started it but seemed to go away. Although this was all at idle and reving engine. Not under a load. Will try that tomorrow. Oil is clear and old oil has no evidence of water.
Old 01-11-2018, 10:10 PM   #12
Old_Gold
Old_Gold's Avatar
In my experience, white smoke usually leads back to water. I would probably do a compression test while the plugs are out, and see if any cylinders are low
Old_Gold is offline   Reply With Quote
Old 01-11-2018, 11:17 PM   #13
1972RedNeck
1972RedNeck's Avatar
I'm sure you're not near as cold as the rest of us, but when it gets below freezing, all of my old vehicles have heavy white "smoke" (actually steam).
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-12-2018, 01:24 PM   #14
demian5
demian5's Avatar
By chance, did you change the intake gaskets, then not drive it at all after that? And this would the oil change that you are supposed to do after an intake gasket change?
If so, then coolant more than likely got in your intake ports when you pulled the intake off and mixed with the oil from the oil leak.
Just a thought.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-12-2018, 04:09 PM   #15
Arl37
Figured it out albeit a little embarrassing. I had a little difficulty setting the timing after replacing the intake and had ended up with only a 4 degree advance in order to get to run reasonably well. Still, just didn't feel like it was running right. Did a little reading last night on the forum and it prompted to see if advancing the timing would solve the problem. Well it was quite to the contrary. Some in early last year, in the process of trying to determine the max advance of the distributor, I had made a timing mark with white paint at 32 degrees advance. Well dumba** me had been using the 32 degree timing mark in stead for the factory mark( which I had also marked white) on the crank pulley. Used the correct mark set it at 12 degrees and runs like a top and no smoke.
I hope this post will someday help someone diagnosing the cause of smoke. Too much advance can make it smoke.
Old 01-12-2018, 05:31 PM   #16
demian5
demian5's Avatar
I don't agree, but I am glad its running good now. keep up posted on the long term if you can. And run a bottle of lucas stabilizer in your motor at next oil change just for extra protection.
1986 C20 Scottsdale
Instagram: C10sofOC
