Old 01-11-2018, 09:01 PM   #1
Buda63
Buda63's Avatar
HELP! Horn Cap and Mounting Hardware
Can someone provide some guidance on what parts I need to put a functioning horn in the original steering wheel (1962 C10). I searched the Classic Industries catalog and Summit and found Part #OER K137 which looks correct but the year in the description 69-72 does not include my truck. Will this work? If not what do I need.
Buda63 is offline   Reply With Quote
Old 01-11-2018, 09:13 PM   #2
Ken Cook
Ken Cook's Avatar
Re: HELP! Horn Cap and Mounting Hardware
LMC sells all the parts you need to put it together. The cap is a little pricy at $60 but the rest of the parts only cost $17.00.
Ken Cook is offline   Reply With Quote
Old 01-11-2018, 11:41 PM   #3
Short 3/4
Great timing. I just spent way too long last night trying to install the LMC kit in my 65. Pictures in kit and factory manual are both vague and contradict each other. Anybody have a picture of the order of parts. every time I tighten all three mounting screws down the horn blows, have to leave two loose for it to work correctly. Don't know if I have the same problem as original poster, or if our years have the same parts, but maybe someone can help us both.
Thanks, Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 01-12-2018, 02:19 PM   #4
Hilandr451
Hilandr451's Avatar
here's what they look like and how they go in. http://www.6066chevytrucks.com/id108.html
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
Old 01-12-2018, 04:16 PM   #5
Buda63
Buda63's Avatar
This is all great info. Thanks for the help.
Old 01-12-2018, 07:46 PM   #6
Short 3/4
Greg,
I thank you as well,
Tom
292-SM420-T221
Old 01-15-2018, 01:15 AM   #7
Short 3/4
Well, thought I had it figured out. Looks like the LMC kit and Highlanders (very clear) directions both apply only to the deluxe horn ring. I have the standard horn button. The LMC parts don't work at all, and when I use the old (very different) parts I have to leave the three 10-32 mounting screws loose or the horn stays on all the time. This does not seem right, what am I missing?
Thanks for any help, Tom
292-SM420-T221
Old 05-09-2018, 11:57 PM   #8
dirtdog604
I am going through the same thing Tom, I have a 60 C10, it had a wooden wheel in it. I bought a new wheel and mounting kit from LMC, cant figure it out. I realized that I needed a mounting cup with a notch in it for the standard cap to fit, but cant buy one anywhere. Took one from a 70's truck, cant seem to make it work. Did you figure anything out?
dirtdog604 is offline   Reply With Quote
Old 05-10-2018, 03:29 PM   #9
Short 3/4
Don't know if your early truck is the same as my 65, but LMC kit does not work for standard horn button on my year. I wound up cleaning up and reusing used parts and would recommend you do the same. Lots of guys parting out early trucks in the parts section of this forum. should be able to find used early 60's parts, and you can probably get seller to take a picture of how it goes together, as lack of a clear diagram was one of my biggest issues
Good luck, Tom
292-SM420-T221
