Wheel well liner clearance 83 gmc - Front
Just installed 3" dropped spindles on my 83 gmc SB. Was planning on cutting the springs to get another 1.5". As it sits without cutting the springs there is about 3" of clearance between the tire and wheel well. Dropping it another 1.5" will leave it at about 1.5" of clearance. Without changing out the wheel wells there doesn't appear to be a way to fix that. Are others running with only 1.5" of clearance? Is there some kinda of trick I don't know about. I don't mind an ocassional rub.
Running 245/45/20. |
Re: Wheel well liner clearance 83 gmc - Front
Let me know if you do remove your wheel wells. I did the 4.5 drop in the front and 6 in rear and only have the inch of clearance so I have been debating what to do since I cant really drive mine now cause it'll rub. I have a 85 C10
![]() Join Date: Dec 2006
Trim away. I've ran several trucks with 4.5" drop upfront with 245/45/20. You should get on the bump stop before you get in the inner fender so leave them in place.
Follow me on Instagram: @midtennc10 Youtube channel: Midtennc10 |
All these trucks were around 4-1/2 and only the blue truck buzzed the fenders on a big bump.
Yeah my inner fenders are metal so I didn't really want to mess with them if I didn't have too. I might put in some spring spacers to stiffen up the front end and see how that works.
Slosh tubz sells a mild drop inner fender
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
$730 ?!?!?!?!?!
RIZ ![]() 81 C10 short box 82 K5 Blazer |
If you have a jack mounted on the wheelwell don,t forget to take it off and the bolt too if you leave inners on, the bolt makes a nice mark in the tire when you hit bumps
Diggin The SquareLife
slosh tubz period
got mine for 400
