01-12-2018, 06:33 PM | #1 |
Hotchkis or Brothers?
Just picked up a '71 C10. I need to drop it, but just a static drop no frame notching or airbags. The Hotchkis 4/6 springs were recommended by someone. From what I've read that is pretty much the max drop without notching. This will be a daily driver, rarely will carry a load. I want smooth handling, more like a car than a rough ride truck.
Reading some threads, Brothers was was also recommended, but it appears they only have a max of 3/5 drop. Combined with their shocks I can get springs and shocks for about the same price I can get just the springs for from Hotchkiss. I'd rather go with the 4/6 and pay a little more to get the extra drop. My question(s) for those who have used the Hotchkis. What shocks are you running with it. Their shocks are a little more than I want to spend and probably a little overboard for my needs. Also is there anything else needed with the Hotchkis like relocator brackets? |
01-12-2018, 08:20 PM | #2 |
Re: Hotchkis or Brothers?
Just me but I don't like that much spring drop for a daily driver. I prefer drop spindles and a longer spring to allow more travel. I also feel it gets you into alignment issues with a lot of spring drop. Bump steer becomes an issue the further you go down with just springs. I have run the KYB and the cross over stuff car quest. The last set I put on the 66 are the bell tech street performance shocks built for these trucks and have been on the truck for more than 20,000 miles of daily driver pounding. Still doing good.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-14-2018, 02:14 AM | #3 |
I'm looking at the BellTech Nitro Drop 2 in conjunction with the springs, just haven't made up my mind between the 3/5 Brothers or the 4/6 Hotchkis. I'm looking for input from those who are running them.
01-14-2018, 03:06 AM | #4 |
If I were to do a 2" drop spindle and a 2" drop spring, I could still achieve the 4/6 drop I'm looking for. Who makes a good drop spindle that lets me use the stock rotor/brakes?
01-14-2018, 11:37 AM | #5 |
CPP is the only one I think that makes a 2" spindle. Lots making 2 1/2". For the rear a 5" spring and a 1" block with a 3degree wedge to correct the pinion angle works well along with a long panhard bar like the Early Classics super track bar.
Jimmy
01-14-2018, 01:14 PM | #6 | |
Currently looking at McGauphy's 2-1/2" drop spindles with Hotchkis 2" coils front and 6" in the rear. Would a spring/block combo be better for the rear? |
01-15-2018, 10:05 AM | #7 |
www.earlyclassic.com 4/6 kit and you'll be happy. If you're not buying the whole Hotchkis kit, the springs are a bit expensive for what they are and do.
Another great option is the Ridetech StreetGrip kit. http://www.ridetech.com/products/sus...etgrip-system/
01-15-2018, 02:16 PM | #8 | |
01-15-2018, 02:48 PM | #9 |
Delete: duplicate post
01-16-2018, 10:13 AM | #10 | |
That's really my only complaint is the KYB shocks they include aren't matched to the drop. Their customer service and other products are top notch, though.
01-16-2018, 01:26 PM | #11 |
Customer service seems to be on top of it. I emailed at 10:43am yesterday, they replied at 2:26pm!
I asked about the spindles and springs as to who made them. They are both made here in the US. The spindles are cast and machined in CA. The coils are made in CA and KS. As far as the KYB shocks, the kit comes standard with the Excel G, but they offer the Gas-A-Justs as an option. (I didn't see that info on the website so I assume you have to call to make that adjustment). Shipping is a killer though, close to $200 from CA to here in eastern WA. 😕 |
01-16-2018, 05:32 PM | #12 |
Tell them you're a board member They used to offer some discounts.
01-16-2018, 09:53 PM | #13 |
You can also find most of the parts on Summit racing and get free shipping. Look at the belltech street performance shocks. MUCH better than the kit shocks.
Jimmy
