Old 01-13-2018, 09:31 AM   #1
BurbFam
Adding a couple inches to 4” suspension lift.
I got a 1991 suburban 3/4 ton 4x4 about a year ago finally getting started on it. The PO never mentioned any lift but I’m about 80% sure it’s got a 4” lift already on it, is there a way i can confirm this? I threw on a 315-75/16 to check my offset of the wheels and they fit pretty good except when i run obviosuly it rubs the fenders. (See second pic)
If it already has a 4” lift, i know i can add 2” block in the rear but i don’t want to put blocks on the front and I’d rather stay away from body lifts. The additional 2” is temporary, just until i can get a 6” suspension lift. I just want something i can add now so i can get these 35’s on it.
Also some research I’ve done shows this truck possibly has the 4l80e transmission. The pan does have 17 bolts but i don’t know how else i could determine which tranny it has.
BurbFam is offline   Reply With Quote
Old 01-13-2018, 09:44 AM   #2
sweetk30
sweetk30's Avatar
Re: Adding a couple inches to 4” suspension lift.
do this http://www.offroaddesign.com/catalog/oneinchlift.htm
with this http://www.offroaddesign.com/catalog/bodymounts.htm
and http://www.offroaddesign.com/catalog/Zero%20Rates.htm
last in 2.5" flavor http://www.offroaddesign.com/catalog/shacklekit.htm
or another zero rate in the rear with no flip kit .
gets you 2" total . levels the rear a bit with the 2.5"flip kit in rear or the 1" only in rear with another zero rate kit. . and new body bushings to replace the 40+ year old rubber ones .
you will need new u-bolts with these items.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-13-2018, 10:02 AM   #3
RyanNewberry
I don’t like adding blocks at all. But, I have a 4 inch lift on my 87 pickup and I run 35s daily and mine doesn’t rub at all. Maybe you only have a 2 inch or 3 inch lift????
RyanNewberry is offline   Reply With Quote
Old 01-13-2018, 10:18 AM   #4
BurbFam
I like what i see, i didn’t realize they made aluminum body lifts, i didn’t want to use body lifts because I’ve heard they crack. I work at a steel fab shop and have access to a CNC plasma table, could i make my own pucks out of mild steel?
Old 01-13-2018, 10:21 AM   #5
BurbFam
That’s possible, i looks like the tire only the ribs the flare not really the fender itself. But i have driven it around with 35s either. Either way it seems i only need a couple inches to clear anyways.
