01-13-2018, 04:54 PM | #1 |
Question on replacing front pillar and cab mount
Hey,
I am currently doing some bodywork on my 72 K25. I need to replace a lot of things, rocker, inner rocker, front pillar, rear pillar, front and rear cab mount and cab corner. I know the list is long and i should get an other cab, but here in Quebec it is just too rare. So here is my problem. Nothing is welded for the moment. As you can see, i have a massive gap between the 2 pieces and the cab mount is not perpendiculary to the ground. Am i missing something here ? The other side seems ok Yes i braced the cab in ''x''. Thank you for helping me ! |
01-13-2018, 06:11 PM | #2 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Question on replacing front pillar and cab mount
Need your inner rocker in place...That's a good pic but need to see more, back the camera away and get a couple of angles...I like to use the panel that incorporates the edge of the floor pan with the inner rocker...Use small self drilling sheet metal screws for temporary holding and fit up, then remove the screws once everything is fit up correctly filling the screw holes with weld...Make sure that door fits before you weld...Number 6 at the bottom of this page incorporates the outer floor and inner rocker in one piece. Use it since your outer floor is missing, you wont need parts 11 or 13 if you use part number 6. The rocker panel will fit right against part number 6... http://www.lmctruck.com/icatalog/cb/full.aspx?Page=13 Your cab support will fit against the inside of 6 on the horizontal floor section as well as the vertical lip section of #6...Saves a lot of time and headache...Dont be afraid to use those screws because a small hole is cake to fill and they suck the metal tight together where clamps wont reach or fit...PS. Pay attention to that little note on cab supports, a lot of guys have beat their brains out trying to fit an OE support over the existing support or wonder why a slip on dont match the welds of the removed original support...Take your time, dont be afraid to make adjustments and by all means, make sure that door fits...Work one side at a time...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 01-13-2018 at 06:45 PM. |
01-13-2018, 06:46 PM | #3 | ||
"I ain't nobody, dork."
Still a lit of sheet metal to go between there. The inner rocker panel and the kick panel get sandwiched in between there.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-13-2018, 07:41 PM | #4 |
Thank for the answer guys.
If i understand, the kick panel and the inner rocker goes between the pillar and the cab support. And the fact it is not 90 degree is not a problem, since i can use metal screw right ? I took more photos here they are. https://imgur.com/a/P3W6H ( Anyone know how to add pics, because they ask a url.. ) When i bought the truck it came with inner and outer rocker as you can see on that last picture. It was those one i wanted to use and just add a sheet metal to fill the gap between the rocker and the floor It is hard for me to fit them, cause the other side is as bad as this one. So can't take measure. Last edited by Aragard; 01-13-2018 at 07:45 PM. Reason: Trying to add pics. |
01-13-2018, 10:18 PM | #5 |
Step 1: I would fit the outer floor extension/inner rocker piece. The inner rocker in Your IMGUR album is junk. It Does not have any material behind the pillars or the proper contour. That is more of a patch for those who do not need total pillar replacement.
Step 2: fit and install the inner kick panel. As you can see it only covers the top two holes of the cab support therefore the tapered gap you have is necessary. Step 3: fit and install the pillar. Once you get to this point the gap should be minimal. Step 4: hang the door, remove striker plate for cab jamb. Step 5: begin fitting the outer rocker. You honestly have a huge job ahead of you. You could save a lot of time and frustration by purchasing a complete cab floor. I know from experience.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
01-13-2018, 10:52 PM | #6 | ||
That outer cab floor extension that includes the inner rocker is by far one of the best patch panels to come from the aftermarket for these trucks.
I used them on both sides of my cab. Made life a helluva lot easier. Gary
01-14-2018, 08:01 AM | #7 | |
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-14-2018, 12:59 PM | #8 |
Hey.
As i read you guy's i see that i really need this #6 piece. I ordered it from classicparts. I didn't knew they would ship to Canada. For the moment, i ordered parts from Bills truck Shop and Rockauto. Rockauto is really hard to beat but dont have specific pieces that i will need. I also ordered kick panel. I think i will have everything i need now. Ironangel, Do you talk about part #9 from http://www.lmctruck.com/icatalog/cb/full.aspx?Page=13 If yes, i have it. I'll post some update when i'll get the parts and try to fit them. Thank you alot guys ! Last edited by Aragard; 01-14-2018 at 01:09 PM. Reason: Adding thing |
01-14-2018, 01:08 PM | #9 | |
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 01-14-2018 at 01:47 PM. |
01-14-2018, 03:01 PM | #10 |
Thanks for the pics and the tip.
Ill definitly try it on the other side. Ill post more info when ill get back to it. |
01-23-2018, 02:52 PM | #11 |
Little update
Classicparts have a broking fee because it has to pass the border. For the 2 parts there was an extra 90 CAD... Finally i ordered from Bills shop truck. The parts are Triplus too. Waiting for them, i started to replace the inner bottom and door skin. |
01-23-2018, 08:44 PM | #12 |
Hey, could be worse. Blazers cover all that up with a giant steel box!
02-15-2018, 03:49 PM | #13 |
Hey,
Sorry for the long delay I finished the passenger door and started on the left side of the cab. I need some information. I installed the rear floor panel with the rear cab support. For the moment it is just tack, but all the holes on the floor lines up with the original one. I lapped it with the original floor. https://imgur.com/a/dL90R I am now going for the floor rocker extension. My questions are Should i lap it with the floor rocker extension ? How to fit it ? With the door ? When i am placing the outer rocker, it doesnt seem to fit right on it. Am i missing a piece between those 2 ? Thank you |
02-21-2018, 02:24 PM | #14 |
Anyone ?
