fender alignment
I am having a problem lining my fender up , it seems like my core support is an inch high . When i bolt the fender on by the door gaps are good but the front is WAY down. Then i lift the front up to try and bolt to the core support and the top of the fender hits the door!!!!
Post Whore
![]() ![]() Join Date: May 2015
Re: fender alignment
what year truck? have you checked cab front mounts?...they may need shimmed
About the same problem I have.....I've decided to put it together the best I can, get it on the road, and take it to a real (experienced) body shop later on for their help. *Attempts to hire, pay all travel expenses, etc., for a forum member to help me have proven futile.
The Older Generation
Are you putting new rubber cab and core support mount bushings in it? If not the originals may be rotted and flattened out.
It also makes a difference if it is a 1/2 or 3/4 ton chassis what kit you use.... LockDoc
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
What he said...Need new rubber in all six locations making sure your using the correct mounts for the correct application. Fine tune with shims, all fenders were shimmed top and bottom to some extent at the cab...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
it could be that the cab/core mounts have settled. you dont want to simple replace the core support ones, just like was said above, replace them all. old and new settle at different rates.
and maybe check the core support itself. maybe it got tweeked in an accindent |
