Old 11-02-2003, 06:00 PM   #1
68c10owner
68c10owner's Avatar
headlights not working
i`ve got a interesting problem. went out to drive the truck the other night and turned the lights on and they did`nt work. the running lights, tail lights, brake lights and high beem all worked fine but the low beam will not work. electrical problems are not my strong point. anyone have any ides? thanks
Anthony
68c10owner is offline   Reply With Quote
Old 11-02-2003, 06:04 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Unplug the high beam switch on the floor and look for corrosion.
With the lights turned off, you can flean the contacts up on the switch and in the plug with a wire brish.
The switch its self copuld be dead too.
Those are the 2 #1 reasons for headlights to not work properly.
Old 11-02-2003, 06:35 PM   #3
cheatham
I need a brake!
cheatham's Avatar
I agree with Andy.
JP
MEMBER OF THE DISCS UP FRONT CLUB
1971 Chevy C10
cheatham is offline   Reply With Quote
Old 11-02-2003, 06:44 PM   #4
68c10owner
68c10owner's Avatar
thanks longhorn. i`ll check it out.
Anthony
Old 11-02-2003, 09:38 PM   #5
68c10owner
68c10owner's Avatar
well i think i found my problem. i got the plug off of the dimmer switch and one of the terminals was melted and the terminal on the dimmer was black. guess it`s time to rewire the truck now.
Anthony
Old 11-03-2003, 12:27 AM   #6
Longhorn Man
Not too uncommon for these trucks.
If you wire up the headlights with relays, not only will you get brighter headlamps, but the wires won't carry so many amps and they won't burn up like that.
Here is a link that will show you how to do it. http://www.classictruckshop.com/club...ead/lights.htm
