01-14-2018, 04:13 PM | #1 |
Suburban 2nd and 3rd row seat mounting
Hey Guys,
Does any one have some good photos of the elevator bolts for the rear suburban seats, specifically how they are mounted to the seat frame? I am converting the GMC style with the tracks to the Chevy style. Just looking for an idea of the spacing and hardware associated. Any info on the specific bolt size and length would be helpful as well Cheers, Anthony |
01-14-2018, 06:47 PM | #2 |
Re: Suburban 2nd and 3rd row seat mounting
I have a 61' GMC with the Cleat style mounts (no tracking/sliding system) in back. Is that what your refer to? Here are some pics of that hardware. (disregard the washers)
MusicMan70 1961 GMC Suburban |
01-14-2018, 09:02 PM | #3 |
Hey Music man,
The bolts you have look different then the bolts I had. These are what where bolted to the bottom of my seat frame. Looking to use the Chevy style mounting system, got a set of these plates from 4-5-6. Just trying to figure out the bolts |
01-14-2018, 09:26 PM | #4 |
Here's another picture of how it mounts in the cleat
http://www.67-72chevytrucks.com/vboa...=cleats&page=2
MusicMan70 1961 GMC Suburban Last edited by MusicMan70; 01-14-2018 at 09:33 PM. |
01-14-2018, 11:39 PM | #5 |
Ok. Beauty! Thanks I see how it goes together. What are the dimensions for the elevator bolt? Diameter of the base, length, bolt size and thread? I have plates welded onto my base for the track bolts. I may have to cut them off and drill some holes through the tubing to mount it like yours.
Cheers, Anthony |
01-15-2018, 01:16 AM | #6 |
read post #45 of the thread I posted for dimensions
01-15-2018, 06:38 PM | #7 |
Mine doesnt have the flat head style carriage bolts as original. I have standard carriage bolts with the square block type washer but I used lock nuts instesd of wingnuts. Only thing I dont like which I will fix later is when I tighten down the nuts, it pulls the bracket up in the center.
01-16-2018, 06:56 PM | #8 | |
Here is how my seat frame is laid out, haven’t seen many like it. |
02-07-2018, 04:22 PM | #9 | |
Hey Music man,
Is it a 3/8-16 by 1 1/2” T-bolt, I thought they were a 3/8-16 by 1 1/2” elevator bolt or carriage style bolt. Or are they 5/16-18 by 1 1/2” or 1 3/4” elevator bolt or carriage bolt? Looks like post 45 talks about the bolts used for tracks. I will be using seats that were fixed into the suburban with tracks but I will be converting them to the post and plate style mounts in the panel. I picked up some 3/8-16 by 1 3/4” elevator bolts and they will not fit the plate, forgot to bring it with me as a reference. Any specifics would help. Cheers, Anthony Quote:
02-07-2018, 10:27 PM | #10 | |
02-10-2018, 07:09 PM | #11 | |
02-10-2018, 07:13 PM | #12 |
A few other pics; They were out of stock on the stainless carriage bolt otherwise I would have used that.
02-10-2018, 10:06 PM | #13 |
