Old 01-14-2018, 09:43 PM   #1
jasnake65
Difference between 1960-63 cabs
Trying to see what the difference is between the 60 to 63 in the cab area. I cant find any good pictures or sites to tell me the difference. I know there was one site but my brain isn't working.
jasnake65 is offline   Reply With Quote
Old 01-14-2018, 09:49 PM   #2
dtkarst
Re: Difference between 1960-63 cabs
To my knowledge, 1960-62 share pretty well the exact same cab which mount on the X-frame. Then in 1963 they did away with the x-frame, which means the cab mounts differently. There may be more but off the top of my head thats a difference. Of course there are differences in the mounting on the supports of the cabs as the truck size got bigger.
dtkarst is offline   Reply With Quote
Old 01-14-2018, 10:37 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
somewhat similar thread:
http://67-72chevytrucks.com/vboard/s...highlight=cabs
66 C20 Service Truck:
Old 01-15-2018, 12:34 AM   #4
Captainfab
60-66 Nut
The firewall on the '60-'62 Chevy's and '60-'63 GMC's are designed for a combination brake and clutch master cylinder. 1963 Chevy and 1964 GMC was the first year for a mechanical clutch.
Old 01-15-2018, 12:47 AM   #5
rvrfoot
Not much different.
rvrfoot is offline   Reply With Quote
Old 01-15-2018, 07:25 AM   #6
jasnake65
thanks for the help, second question is about wiring. I want to replace all of my wiring since its old and not charging. Speculation has I have some 63 stuff on a 60 frame. My regulator is from a 63, key switch and steering wheel. Has a 350 in it, do I buy the wiring from a 60 or a 63?
Old 01-15-2018, 12:20 PM   #7
rvrfoot
Get a 63.
Old 01-15-2018, 08:09 PM   #8
jasnake65
thanks for helping me!!
Old 01-17-2018, 11:25 PM   #9
rvrfoot
If you have any more questions just ask. We are here to help you.
Old 01-18-2018, 12:43 AM   #10
UKNOWME
UKNOWME's Avatar
Originally Posted by rvrfoot View Post
Get a 63.
Can you educate me? I may decide to rewire my 61. Why 63 wiring?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-18-2018, 08:06 PM   #11
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
The 63 cab in the parts book is listed as a replacement part for 60-62. You had to drill a second hole on the firewall for the hydraulic clutch setup and to relocate the cab mount reinforcement on the front supports to the center plateau where as the 63 cab mount were on the inner plateau closest to the transmission.
