Old 01-15-2018, 04:00 PM   #1
riz
drop shocks?
what is the best shocks out there for a truck lowered 4.5/5 in the front and 6/7 in the rear? Is it better to go drop shocks or regular shocks with shock extenders? I'm looking for the best ride possible..... thanks in advance.
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 01-15-2018, 05:43 PM   #2
SCOTI
SCOTI's Avatar
Re: drop shocks?
The 'best' shock is subjective.
Ride quality comes from proper valving & stroke/travel. Many 'drop' shocks are usually just shorter shocks which limits the travel. If relocation brackets for mounting are available, they would be a better option.
As for quality of shocks? I like Bilsteins for off the shelf replacement shocks. An even better choice would be Ride Techs HQ series shocks. With the HQ's, you can dial in the resistance to your preference & they can be ordered in multiple lengths to obtain the best fit for your set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-15-2018, 06:30 PM   #3
Bobby Pootz
Bobby Pootz's Avatar
Re: drop shocks?
Having just done my rear flip, the shock extender bracket is a must. It will reposition your shock properly. The front only needs shorter shocks.
I should note, that the stock bolt on my 84 would not fit through the hole in the shock extender which is a Western Chassis. So if you might want to be sure you have all the right parts when you start.
The shocks are subjective. I used McGaughy's but only cause I bought the kit. If I have the funds in the near future, I will probably upgrade to RideTech HQ shocks.
1984 C10
Bobby Pootz is offline   Reply With Quote
Old 01-15-2018, 06:52 PM   #4
SCOTI
SCOTI's Avatar
Re: drop shocks?
Front shock relocation brackets are available or easily built allowing you to utilize original length shocks. All of my dropped trucks have been done this way.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-15-2018, 07:47 PM   #5
Nick_R_23
Nick_R_23's Avatar
Re: drop shocks?
My truck is lowered 4.5" front and 6" rear (1 coil cut from stock springs, 2.5" drop spindles, and flip kit with thicker bracket). I made my own drop brackets for the rear axle and used stock replacement Napa-branded gas shocks. I actually ended up using the same stock replacement Napa shocks for the front too, without a bracket. They listed the specs online and it turned out it was actually a bit shorter than the factory shock. I checked the A-arm travel and the shock still had movement when the A-arm was both bottomed out and at full extension. Might be an off the shelf solution if you're willing to do a bit of research?
Old 01-15-2018, 08:18 PM   #6
riz
Re: drop shocks?
https://www.ebay.com/itm/Bilstein-B6...ZZg~2w&vxp=mtr
Are these the bilsteins you're talking about? How are these used on lowered trucks? I'm thinking shock extensions in the rear.... how about the front?
RIZ
81 C10 short box
82 K5 Blazer
Old 01-17-2018, 04:03 PM   #7
photo-tom
Re: drop shocks?
I've always bought Bilsteins. Can't do wrong. They don't make a "drop shock" specifically for the chevs, so I found a guy that sourced the proper sizes from a Dodge Dakota and Cherokee:
https://www.shockwarehouse.com/site/...t.cfm?id=15055
https://www.shockwarehouse.com/site/...t.cfm?id=14389
photo-tom is offline   Reply With Quote
