Edelbrock AVS 2
anybody try the new edelbrock avs 2 carb? if so, how do you like it?
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Edelbrock AVS 2
I know this is an old thread, but searching the forums, this is the only thread I found.
https://www.edelbrock.com/avs2-carburetors It sounds interesting - in that I could see how the "annular flow booster design" may deliver improved fuel atomization. I also wonder, if it really is a superior method, if edelbrock couldn't build a replacement part to upgrade our current edelbrock carbs with "Downleg boosters" to "Annular boosters" ![]()
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
![]() Join Date: Jan 2001
Re: Edelbrock AVS 2
This has been discussed on here before. The "booster" is the accelerator pump, so it's only operating when you're pushing down on the pedal, not when you're holding it steady. I doubt you would see a great deal of improvement.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Re: Edelbrock AVS 2
Thanks, I missed the previous discussion.
![]() Join Date: Mar 2015
Re: Edelbrock AVS 2
Interesting, this little gizmo is supposed to do the same thing, atomize the fuel spray. I did put it on my Eddy carb and it did seem to help on initial acceleration, not as much hesitation. Something to do with modern gas w/ethanol not atomizing as well.
Cheaper than a new carb..... https://thompsonperformance.com/ |
Re: Edelbrock AVS 2
>>This has been discussed on here before. The "booster" is the accelerator pump, so it's only operating when you're pushing down on the pedal, not when you're holding it steady.<<
NOT Accelerator pump nozzles are paired in front. The Booster Edelbrock is referring to is also called a Secondary Venturi. Not to be confused with primary and Secondary Throttle Bores. The Throttle bores, Primary & Secondary are called Primary Venturis. The Booster Ring is the Secondary Venturi. The discharge from the Booster comes from the Main Fuel Jets, NOT the Accelerator Pump. norcalc20LWB, your gizmo is a modification to the Accelerator Pump Discharge Nozzle. |
#7 | |
Re: Edelbrock AVS 2
Re: Edelbrock AVS 2
Elebrock is probably right. It most likely is an improvement but probably not that noticeable. If you have an avs 1 carb is it not mostly likely a good investment to "upgrade" to the avs 2. But what do I know? I have a quadrajet.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
Re: Edelbrock AVS 2
I agree with 71gmc even though I have no experience with either Edelbrock AVS.
I do have experience with the original Carter AVS on a Mopar and I have had a Carter AVS on my 292 for about 15 years. I like it much better than the original Carter AFB or the standard edelbrock. |
Re: Edelbrock AVS 2
That takes me back to the second part of my question above:
"I also wonder, if it really is a superior method, if edelbrock couldn't build a replacement part to upgrade our current edelbrock carbs with "Downleg boosters" to "Annular boosters" ![]()
