01-15-2018, 05:35 PM | #1 |
E brake pedal and cable question
Does anyone have a picture of the e-brake assembly under the dash.
I'm not exactly sure where this black bracket locates along the cable. I thought it would be pretty self explanatory once I got under there, but I guess I'm just an idiot and can't figure it out without pics
______________________ www.northeastrodrun.com |
01-15-2018, 07:31 PM | #2 |
Old member
Re: E brake pedal and cable question
That clip held the cable straight on the braket so it couldn't bind up.
See the 2 holes on bottom that's where it mounted to hold the factory cable in place.
01-15-2018, 07:37 PM | #3 |
I could see where it located on the assembly, but I don't know where it locates along the cable.
thanks for the input though, I appreciate it
01-15-2018, 07:53 PM | #4 |
Old member
It can't go but one place. The tab goes in the smaller hole and the other is for the bolt.
01-15-2018, 08:05 PM | #5 |
Does this help?
01-15-2018, 08:58 PM | #6 |
YES!
Thank you so much. That is exactly what I needed I guess my clamp is crushed down to much, because it would have never fitted over the cable like that. You rock. Thank you so much!!!!
01-15-2018, 09:34 PM | #7 |
Ditto, Thanks for the Great Photo. I need the same photo for reassembly. I would have put it on upside down and backwards 1st.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
