Old 01-15-2018, 08:44 PM   #1
chevy49
chevy49's Avatar
camber corecting control arms
what brand would be best bang for my money the money is of limited supply
chevy49 is offline   Reply With Quote
Old 01-15-2018, 09:13 PM   #2
PGSigns
PGSigns's Avatar
Re: camber corecting control arms
There is a thread on a Caster mod in the suspension section. I did the mod and drilled my locating holes 5/8" back to move the lower control arm ahead and was easily able to run 4 degrees of caster. A couple of hours work and a 5/8" drill bit in the drill press is what it took.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-16-2018, 09:42 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Here is the link - http://67-72chevytrucks.com/vboard/s...d.php?t=501241
Old 01-16-2018, 04:22 PM   #4
contagious102
contagious102's Avatar
Lots of info on the Caster , but not camber ??
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 01-16-2018, 09:45 PM   #5
PGSigns
PGSigns's Avatar
Never had a problem with camber. Always came out good on alignment. I did switch to the 73 to 87 control arms on my 66 when I dropped it and also installed the longer mount bolts when I did it. I am running 2" springs. Camber gain is not bad with this setup. Now the 65 with air had a good bit of camber when aired out but at normal ride height was at 0. What are you trying to do with you trick?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-18-2018, 12:59 AM   #6
rvrfoot
cpp tube arms.
rvrfoot is offline   Reply With Quote
