Truck Farmer
option code ?
Can anyone tell me the rear ratio with just option code. G80 is the code for the posi unit. Dont want to pull the cover unless it is necessary. Thanks
Arizona rust free sheetmetal |
Formerly yellow72custom
On a 1/2 ton truck, models with a standard 6-cylinder (or small V8, 283/307) engine usually had factory 3.73 gears. 350/327/396/402 equipped trucks usually had 3.07 gears.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Its not that easy to tell but... if this is what you want here it is for 1/2 tons.
H01 is 3.07 H05 is 3.73 H04 is 4.11 If you dont have any option code listed it probably has the standard equipment... most like if it s a 6 cyl it's 3.73 if its an original 8 it's more than likely 3.07
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Truck Farmer
OK, this is a 1/2 with factory installed 350. I was hoping the option code G80 on the glove box sticker was a clue for the ratio. Guess it just means positraction rear.
Rod, Those numbers you gave are they the ones on the id tag on the rear housing? Thanks guys.
![]() Join Date: Sep 2003
Jack up the rear end and put a mark on the drive shaft. Turn the right rear tire 1 revolution (if you have a posi) or 2 revolutions (for an open) and count the drive shaft revolutions. This will get you in the ball park.
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
if its an original 350 truck i will bet it has 3.07's if not it would have the optioned listed for 3.73 gears.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
There is a series of numbers on the top right hand side of the axle. The first 3 letters will be the numbers that you need to decifer the gear ratio and wether or not it is a possi. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
![]() Join Date: Aug 2015
Re: option code ?
Who was the manufacturer of these axles? My 6 Cyl. Has the G80 code as well thanks for the info!
![]() Join Date: Jan 2002
Re: option code ?
GM build the 12 bolts. They weren't outsources. Was the original posters truck a 4 speed or automatic transmission?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Re: option code ?
But the OE positraction units were.......Spicer? Ugh, I can't remember.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
