Old 01-16-2018, 12:47 AM   #1
bennylava
bennylava's Avatar
Good front end rebuild kit with no grease fittings?
1987 Silverado 5.7L 2wd. I'm looking for a good quality complete front suspension/steering rebuild kit, that does not use grease fittings. Like the truck would have had from the factory. Can anyone recommend a good kit to replace all the wear parts?
My main question asked, I realize I probably need to say this stuff:
I know most people love their grease fittings. I do not. I feel I do enough maintenance without all that. They also always seem to end up caked in gunk and quite nasty. The quality parts last 50-60k miles (or more) without grease fittings, and I'm fine with that. Especially since I might put 10k miles on the truck, per year. I'm not interested in why parts that you can add grease to are better. I'm just looking for a quality kit that is up to factory oem standards, that does not use grease zerks or whatever. Thanks in advance!
bennylava is offline   Reply With Quote
Old 01-16-2018, 08:09 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Good front end rebuild kit with no grease fittings?
not sure if I follow your train of thought but if you don't like greasing a truck then just don't do it...wont matter if the fittings are there or not
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-16-2018, 09:34 AM   #3
sweetk30
sweetk30's Avatar
go moog and then get a pack of grease fitting caps and put them in after you grease them after install .
and rockauto for great prices on the parts .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-16-2018, 12:29 PM   #4
bennylava
bennylava's Avatar
Everybody will tell ya you're supposed to do it every oil change.
Old 01-16-2018, 03:02 PM   #5
Tom
driving is in my blood
Tom's Avatar
Guess I'm not everybody. I do it every few years, when I remember. But quality and no fittings doesn't go together, anyone worth a dam will have them there because they are better if you use them. If you don't, they are no different then ones without fittings.
Old 01-17-2018, 01:13 AM   #6
jkk
jkk's Avatar
No grease fittings sell more parts
jkk is offline   Reply With Quote
Old 01-17-2018, 07:38 PM   #7
bennylava
bennylava's Avatar
Educational thread for me, the replies are much appreciated.
So now more questions:
What about blasting off all the old grease/gunk from the parts that have grease fittings? When you/they pump in some new grease, often times some of the old grease comes out the top. On my truck, it seems this has been done quite a few times, on all the greaseable parts. Now you've got years of caked gunk built up. So blasting off all that old gunk with a power washer - Good idea? Or bad idea? Maybe water gets between the rubber and gets down in the little ball and socket somehow.
Old 01-18-2018, 08:11 AM   #8
D13
D13's Avatar
For our vehicles, no grease parts are usually short lived. That's fine if your truck is a 3000 mile a year street cruiser. More miles, more load, get the good stuff (MOOG) and use good grease.
The proper way to grease something with seals is to grease until the seal just swells. Forcing grease out past the seals unseats the lips and makes a mess, and a route for water intrusion. Unfortunately in todays world of powered grease guns and untrained operators it is a reality.
Better than power washing is to use a dull tool to remove the worst of the mess, then apply a good cleaner (Simple green etc), let soak a bit, then scrub and floow with a light power wash. Of course, if you are planning to replace the parts and just want the surrounding areas clean, blast away. You will still get better results if you take the big chunks off first.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-18-2018, 08:24 AM   #9
cadillac_al
On my hot rods I will wipe the grease off after I grease it. There will be no need to pressure wash anything if you wipe the grease off after greasing.
My 76 K10 has 185k miles on the original ball joints and U-joints with no grease fittings. I used to think they were inferior without grease fittings but I guess they were perfectly fine for most people. If I mud bogged the truck like my K20 the ball joints wouldn't have lasted this long. If you run through water and mud you need to grease all the joints to get the water and mud out. Running down the highway or dirt roads or snow isn't too hard on all the joints and the original grease seems to stay put.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-18-2018, 02:49 PM   #10
bennylava
bennylava's Avatar
Sounds good. I'll make sure I do that when I first put the new moog parts on.
However, when I do finally need to grease it again someday, where will the old grease go? I can only assume the old grease will be forced out past the seals and unseat the lips and make a mess, just as you said. I'm find with cleaning it off, but it seems like in the end you're still going to get that route for water intrusion. Just trying to learn the best ways of doing these things.
Old 01-18-2018, 08:34 PM   #11
hatzie
Moderator
hatzie's Avatar
Take a rag and wipe it off. That's why we call em grease rags.
I usually leave some grease on the Zerks til it's time to service the joints... just not a huge blob. It keeps the rust away.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
