Old 11-02-2003, 08:12 PM   #1
Hogsbreath
power steering
the steering on my 72 c-10 is acting up. when left idling in the driveway the wheel would slowly turn by itself, but not all the time. the power assist is very poor or jerky. any ideas whats going on
Hogsbreath is offline   Reply With Quote
Old 11-02-2003, 08:16 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Check your PS fluid before you do anything....
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-02-2003, 08:29 PM   #3
Hogsbreath
fluid level is ok
Old 11-02-2003, 08:30 PM   #4
lukecp
lukecp's Avatar
In that case, bad power steering is usually caused by a loose belt, or the pump itself is going bad.
Old 11-02-2003, 08:45 PM   #5
Hogsbreath
is there any way to check.could the problem be in the steering box
Old 11-02-2003, 09:27 PM   #6
john
member #16
john's Avatar
Is there any binding in your column? Some times a misalignment problem will cause this. Bad cab mounts, strg column brgs, etc. if not its probably in the box. Good luck John.
john is offline   Reply With Quote
Old 11-03-2003, 12:30 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Maybe it is time to call Ghost Busters?
I have NEVER heard of that happening.
Old 11-03-2003, 01:33 AM   #8
1969 GMC
1969 GMC's Avatar
hmm...if i turn my wheel to almost full lock (either side) it will go back a little bit, but it won't re-center itself. i have factory PS, good fluid, new(er) belt.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
