01-16-2018, 09:31 PM | #1 |
Stubborn block plug
I need to remove the plug in the driver's side of my block, so I can get the stock temp gauge back to normal operation.
Looks like the plug has been in a while, and without cranking too damn hard, I have not been able to budge it with a 2' extension. Any suggestions? I did soak it with penetrating oil. Too cold out to mess with it now. Longer extension? Impact? Curse at it?
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic |
01-16-2018, 09:51 PM | #2 |
Re: Stubborn block plug
Might try with hot engine if possible. Heat sometimes makes it easier.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
01-17-2018, 07:26 PM | #3 |
Double check which way to pull it. It seems stupid but most of us have done the tighten instead of loosen trick. Sometimes it WILL help to give it a push in the tighten direction, then go back to loosen.
2nd on try it with a warm motor. |
01-17-2018, 08:39 PM | #4 |
I'll try it warm, but not looking forward to hot water gushing out on me,,,
So, what about an impact?
01-17-2018, 10:26 PM | #5 |
My suggestion is to heat the surrounding block area around the plug with a MAP gas torch or similar to expand the threaded area of the block.
01-17-2018, 11:32 PM | #6 |
If it breaks loose when the motor is warm, nothing says you have to fully remove it then. You can wait until things cool off.
01-18-2018, 12:09 AM | #7 | |
But sometimes I don't think of the obvious things. That is why I post here. Thanks
01-18-2018, 08:34 AM | #8 | |
I can't imagine the frustration you have been going thru with that temp sensor. When I did mine and got the radiator fluid back in, I let it run to burp it. When I was sure it was ready, I shut the truck off, but didn't put the radiator cap back on. The truck started chugging & backfiring, fluid was shooting out everywhere!! I was pissed. So had to start the process all over again, jeez!!
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 01-18-2018 at 08:40 AM. |
01-18-2018, 11:58 AM | #9 | |
My truck interior has been gutted for a good while now. Installing new Dash pad, new cluster lens and clock, temp gauge, flooring, seat cover, stereo, etc. 'Bout ready to HAVE IT DONE!
01-18-2018, 12:00 PM | #10 |
Been there, did all this too, about 3-4 yrs ago. Hang in there, it will all be worth it when its finally done.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-20-2018, 11:14 AM | #11 |
The map gas heat works great.
