Removing wiper motor?
Trying to pull the wiper motor, is it as simple as removing the hex nut on the dash? After pulling the knob there was what looked like a jam-nut which I tried to turn loose. It snapped right off.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Removing wiper motor?
That is a wiper switch not a wiper motor. I can't quite tell in the pic if there is something that should not be there, but typically you just need to unscrew the bezel nut with the 2 oblong dimples, from the wiper switch. Then it all comes out of the dash.
Yep, didn't mean to say motor. I typed that after a seven hour drive and my brain was a little frazzled.
Thanks for the reply. |
![]() Join Date: Aug 2008
Those are bezels that like they were painted at some point. They screw off.
