Old 01-18-2018, 01:10 AM   #1
Jbeard
Tools to keep in the Truck at all Times?
Howdy all!
Just got my dad's 72 C10 Longbed going again and am currently driving it daily to college.
One of my next major steps is getting together a good group of tools to keep under the bench seat for the eventuality of break downs.
Was hoping to hear what other guys keep in their truck and also what kind of bags or whatever else y'all use to keep them organized.
Particularly interested if anyone keeps a jack in the truck and if so what kind?
Had a flat the other day, and had to call triple A because I didn't have a jack...
-Jarrett
Jbeard is offline   Reply With Quote
Old 01-18-2018, 01:35 AM   #2
JMC1965
JMC1965's Avatar
Re: Tools to keep in the Truck at all Times?
1. Fire extinguisher
2. Battery jumpstarter
3. AAA card
4. small bag w/ some wrenches, sockets, screw drivers, tape, flashlight
A lot of good advice in these
http://67-72chevytrucks.com/vboard/s...d.php?t=468764
http://67-72chevytrucks.com/vboard/s...d.php?t=482097
JMC1965
1967 C20 LWB
  • 350 (ATK-HP32) / FiTech EFI
  • 4L60e / 4 wheel disc brakes
  • 20" American Racing VN327 & 245/50/20 Michelin
JMC1965 is offline   Reply With Quote
Old 01-18-2018, 07:54 AM   #3
Don Quixote
Don Quixote's Avatar
Around town I carry 2 sets of open end wrenches, a 4 way, a bottle jack and a tire plug kit. I do carry a fire extinguisher. When I'm taking out cross country, I carry a full Craftsman tool set, an ordinance tarp, a blanket, a gallon of motor oil and a bottle of 80/90. I also carry a can of brake fluid and some extra windshield washer fluid. I keep everything but the fire extinguisher in the tool box. In the glove box I keep black tape, fuses and butt connectors and a few extra relays.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 01-18-2018, 09:49 AM   #4
sick472
sick472's Avatar
HEI truck drivers often carry a spare module and I have had a coil leave me stranded in the recent past. Don't forget jumpers and a first aid kit...
The 73+ trucks have a jack that mounts nicely to the inner fender under the hood, check that out. IIRC there is a long folding crank handle that typically went behind the seat with it.
We'll have the bed of your truck full before too long!
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 01-18-2018, 02:07 PM   #5
HO455
Post Whore
HO455's Avatar
I carry a cheap multimeter. I prefer an analog one as the battery will last for years and even if it is dead the voltmeter will still work. Plus I have a 24" 1/2" drive flex handle with a a cheater pipe and socket for the lug nuts. (Got burned once by Led Schwab over torquing lug nuts and the lug wrench we had wouldn't budge the lugs.). Photo of one the jacks in my Burban. It is similar to what Sick472 mentioned. ( I installed this one and then months later found a factory jack with the mount and handle at a wrecking yard. So I now I have two.)
RIP Bob Parks.
Old 01-18-2018, 02:46 PM   #6
Coley
Coley's Avatar
Smile Re: Tools to keep in the Truck at all Times?
Ok, here are my basics:
Tools:....well first find a reasonable 'mid-sized' low profile toolbox which will fit under the seat....then:
-combination wrench: 1/4" to 5/8" (plus I like to keep extra 1/2" & 9/16")
-Screwdrivers: Philips (small, medium) & flat blade (small, medium & large)
-Adjustable wrench (medium)
-Socket Driver (3/8") & 3" or 4" extension for it.
-Sockets....1/4" to 5/8" (...maybe 3/4")
-Needle nose pliers (medium)
-Linemans pliers (med-large)
-Vise Grip pliers (small to medium...not both)
-Wire cutters (small-medium....or use the wire cutters on the linemans pliers)
-Razor knife (w spare blade)
-Ball pein hammer (small-medium)
-Pry bar (medium size....or use the large flat blade screwdriver...on or the other)
-small plastic container with some hand cleaner in it (old film 35mm film case or something similar)
-& a few spare bolts....1/4"NC, 5/16"NC, 3/8"NC not too long & a few nuts and washers to go along...miscellaneous small extras.
-At least a dozen plastic zip ties (tie wraps?).....some bigger ones, medium ones and some small ones....easy, cheap and don't take up much room.
Ok, all of the above will easily fit into a fairly small toolbox. if you want to add a few things...go for it.
Also, 'under the seat' stuff:
-A couple of spare, clean cotton cloths/wrags.
-Jumper cables (easy)
-optional: a piece of reasonable size cardboard that will slip in behind the seat against the gas tank....you can lay on this if you need to. (cheap, easy)
Glovebox stuff:
-A good flashlight
-pack of matches or a good lighter
-at least (2) good pens/pencils and a simple, small notepad
.....and of course a simple jack and a correct wheel wrench for your lug nuts and a small fire extinguisher is always a good idea.
Ok....for me that is about it.
If I have a problem at the side of the road that exceeds what these tools can do....I'm usually into a tow situation. However those will see to about 90% of any problems you might experience.
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 01-18-2018, 03:27 PM   #7
JMC1965
JMC1965's Avatar
Coley is prepared !!!
JMC1965
1967 C20 LWB
Old 01-18-2018, 03:30 PM   #8
Jcfcamaro
Jcfcamaro's Avatar
Bottle opener!
Jcfcamaro is offline   Reply With Quote
Old 01-18-2018, 04:18 PM   #9
harpo231
harpo231's Avatar
Buildin new 67 m no tools for me
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 01-18-2018, 04:31 PM   #10
Coley
Coley's Avatar
Originally Posted by Jcfcamaro View Post
Bottle opener!
...whew!....good catch, I missed that one.
Always important for any and all tailgate parties and social affairs.
lol
Coley
2000 Dodge Ram 1500
Old 01-18-2018, 04:37 PM   #11
Bomp
Bomp's Avatar
Along with jacks, tool box full of tools, sometimes an extra battery ALWAYS have a cell phone and charger cable.
Bomp is offline   Reply With Quote
Old 01-18-2018, 05:19 PM   #12
jojomiamia
Just a big cigar, close to my glovebox ;-)
jojomiamia is offline   Reply With Quote
Old 01-18-2018, 05:32 PM   #13
6768chevylover
6768chevylover's Avatar
I had an alternator bracket break on me. I had tie down straps with me and used them to position the alt. in the spot it was in. I drove 100 mile with this till I was home. Voltmeter was up and down but it worked. Forget triple A...hahaha
6768chevylover is offline   Reply With Quote
Old 01-18-2018, 06:04 PM   #14
sick472
sick472's Avatar
If your vision is goin like mine (far sighted), a pair of cheater glasses would be most valuable for a repair. Mine are always on the dash!
AND a small 12 volt air pump for flat tires.
Next question...where to store emergency items when under the seat is FULL?
1972 C10
1985 K20
Old 01-18-2018, 06:39 PM   #15
1972RedNeck
1972RedNeck's Avatar
Set of end wrenches, Leatherman, .357 Mag, 6 way screwdriver, tire iron, hatchet,first aid kit, fire extinguisher, ammo, and bottle jack.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-18-2018, 08:10 PM   #16
custom10nut
custom10nut's Avatar
At a bare minimum.
Pliers, 8 inch adjustable wrench, combo wrenches between 3/8 and 3/4 (also metrics the same size range), flat tip and Phillips screw drivers, and a roll of duct tape. Fits nice in a small bag and stashes next to the factory jack. I've never had to use any of my tools on my on my own vehicles but have helped more people than I can remember on the side of the highway.
custom10nut is offline   Reply With Quote
Old 01-18-2018, 09:31 PM   #17
joeydurango
joeydurango's Avatar
What tools to bring?
All of 'em.
Well, not quite. But I have a case full of tools sitting in my bed-mounted toolbox. Too much to list, but I could repair or replace most things on the side of the road if needed. That tool case must weigh at least 50 pounds. If I don't have the tool to fix it on hand, I probably have the tools to make it work long enough to get home to my garage and the rest of my tools.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 01-18-2018, 10:48 PM   #18
CastIron
CastIron's Avatar
I was about to ask the same thing. Anybody doing anything interesting for storing tools? I was thinking about mounting an old steel ammo box under the hood, somewhere near the voltage regulator. They are tough, waterproof, and can hold quite a bit.
CastIron is offline   Reply With Quote
Old 01-19-2018, 12:12 AM   #19
joeydurango
That would be cool - as long as you padded the inside and separated the tools somehow. Otherwise I'd think you'd get quite a lot of rattle in there.
Old 01-19-2018, 12:25 AM   #20
El Dorado Jim
Bottle opener!
the silver metal piece on the end of the seat belt is the best bottle opener,atleast on our old trucks
El Dorado Jim is offline   Reply With Quote
Old 01-19-2018, 04:43 AM   #21
Jbeard
Thanks for all the Replies!
I'll start gathering tools and spare parts tomorrow. I think I have a smaller toolbox I might take a sanding tool to that will work perfect with a fresh coat of paint on it to match the truck
Made a good sized order from LMC the other day, mostly grommets and other small stuff like that. I'm most excited about putting the two rubber standoffs on for the glove box door so that it will stop rattling at speed. Oh, and installing new vent seals so that my left leg will stop being blasted with a crisp wintery breeze. HAHA
-Jarrett
Old 01-19-2018, 08:09 AM   #22
In my work trucks I carry basic hand tools since I am carrying tools of my trade and often need a wrench or other anyway. But generally, unless I am off on a long trip, I don't carry any tools. I carry jumper cables, a length of chain, and a container of each fluid. I should carry a roll of wrenches like I do on my Harley, but never put anything together. These trucks just seem to get me home no matter what...with or without mine or someone else's tools. I guess I've just been lucky enough to have what I needed when I needed it. But I think I'll put a set of combination, allen, screw drivers, punch, hammer, pliers together now that I'm thinking about it.
Old 01-20-2018, 10:04 PM   #23
mike16
1911?
mike16 is offline   Reply With Quote
Old 01-20-2018, 10:10 PM   #24
joeydurango
Originally Posted by mike16 View Post
1911?
That is one tool that will probably get you into more trouble than out...
Old 01-20-2018, 10:24 PM   #25
1967GTO
I had a alt bracket bolt break on mine and had to borrow a big c-clamp and a 2x4 to get home.
I don't know how many people I have helped that don't have the correct size lug nut socket to fit their new wheels.
I will add some vise grips to the list. Very handy for many things. Also ratchet tie down straps
1967GTO is offline   Reply With Quote
