Old 01-18-2018, 03:55 PM   #1
Big Blue
Big Blue's Avatar
Fuel Sending Unit
Hello Everyone, Hope this is in the right location. I have a 1979 k5 blazer. I need to purchase a fuel sending unit for it. The Problem I am having is choosing the right gallon size. Does it really matter what gallon size? It has currently a 4 tube outlet. So is it a 25 or a 31 gallon? Thanks, John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 01-18-2018, 05:59 PM   #2
Jstock85
Re: Fuel Sending Unit
I don't think gallon size matters as long as you replace with another 4 outlet sender.
Jstock85 is offline   Reply With Quote
Old 01-18-2018, 06:59 PM   #3
raceman6135
Dino burner
raceman6135's Avatar
Yes, it matters what size the tank is because the 25 and 31 gallon tanks are different depths (approximately 2 inches different).
raceman6135 is offline   Reply With Quote
Old 01-18-2018, 07:19 PM   #4
Big Blue
Big Blue's Avatar
Thanks both of you . I still have the old one. What if I measure the lip where the seal goes, down to the tip of the filter pickup, can that help me get the right one?
Big Blue ( John )
Old 01-18-2018, 07:26 PM   #5
v30crewcab
v30crewcab's Avatar
I think on lmc site they list tank measurements so you can figure out what size tank you have.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-19-2018, 09:14 AM   #6
Jstock85
I stand corrected. Thanks for the info
Old 01-22-2018, 12:13 PM   #7
raceman6135
Dino burner
The 25 gallon tank is 10 3/4" deep. The 31 gallon tank is 12 3/4" deep.
I would just measure the tank itself; that way you can be sure you're comparing apples to apples when looking at LMC Truck, Spectra Premium's website, Rock Auto, etc.
