01-19-2018, 06:20 AM | #1 |
Ignition Cylinder Problem.
The cylinder in my 77 k10 stuck in the run position. I've stripped down the column and knocked out the casting covering the tang that needs to be depressed to remove the cylinder from the column, but the tab/tang doesn't budge.
Can anyone offer a suggestion on how to proceed. as a last resort I'll use a slide hammer to pull the guts out. Thanks |
01-19-2018, 07:17 AM | #2 |
Re: Ignition Cylinder Problem.
We had some good threads with good pics on this the last couple years. It's a 2 day job. The first day you try everything and get pissed. The 2nd day it seems to come apart. My trick was to use a steak knife to stab that little tab a couple hundred times. It seemed none of my little screwdrivers were working.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-19-2018, 08:12 AM | #3 |
There are videos on youtube that may be helpful. Helped me last year replacing mine. If it won't move out of the run position, that may be an issue with removing.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
01-19-2018, 11:14 AM | #4 |
I was thinking that also but the new replacement cylinder seem to push in in ant position. As far as online vid's now that I found address the tab being stuck.
If you know of any could you link them here? |
01-19-2018, 12:12 PM | #5 |
79 Chevy 2wd BIG10 350 TH400 |
01-19-2018, 12:45 PM | #6 |
Thanks Truckin, but thats a late model column with the screw pin, mine has the tang near the end of the cylinder.
