Old 01-19-2018, 02:37 PM   #1
woodrow123
71 C10 4x2
Hey all, I'm a brand new C10 71' owner. My truck is pretty stock and has coil springs all around. I would like to level out the front and raise the truck in total about 2". I am looking at coil spacers since that seems to be the only thing available to do on a 4x2 to achieve the look I want. Would it make sense to install these? (3 inches in the front and 1.5 in the back is actually all I can find online). Would I need to replace the shocks as well and anything else? Thanks for your help!
woodrow123 is offline   Reply With Quote
Old 01-19-2018, 03:02 PM   #2
geezer#99
geezer#99's Avatar
Re: 71 C10 4x2
Welcome to the zoo!
What do the rear spacers look like? The front and rear springs are installed differently.
geezer#99 is online now   Reply With Quote
Old 01-19-2018, 03:42 PM   #3
notsolo
notsolo's Avatar
Re: 71 C10 4x2
Welcome aboard, Great looking truck! I have the sister to your truck, going to be almost same color comb. I went the other way as far as leveling the truck. 2.5" drop spindles and 2.5 drop shackles in the back. Leaf springs on mine. Try different word combinations in the search bar.
notsolo is offline   Reply With Quote
Old 01-19-2018, 05:07 PM   #4
woodrow123
Re: 71 C10 4x2
Thanks Guys!
The Spacers would be for the front: https://www.ebay.com/itm/CHEVY-C10-F...8AAOSw4i5Zraje
And back something like this trying to find in black: https://www.ebay.com/itm/1-Rear-Coil...oAAOSwF09ZdiUp
Old 01-19-2018, 06:01 PM   #5
sick472
sick472's Avatar
Re: 71 C10 4x2
I would bet that the shocks will need to be changed especially in the front. 3 inches is a big change. At least figure out what shocks you have and have a shock manufacturer tell you what would work best.
Check out your flexible brake lines too. Two in the front, one in the back center (I think). They may need to be longer as well.
I'm no expert on lifting trucks, but sometimes the drive shaft angles can become undesirable as well as the pinion angle. Hopefully someone will chime in with some experience in the matter.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 01-19-2018, 06:16 PM   #6
geezer#99
geezer#99's Avatar
Re: 71 C10 4x2
Originally Posted by woodrow123 View Post
Thanks Guys!
Those should work.
The back ones sure aren’t cheap.
I’d drill a hole in a new hockey puck and use a big flat washer for that price. LOL!!
Pinion angle shouldn’t be a problem with that slight rise.
Old 01-19-2018, 08:44 PM   #7
Mike C
Mike C's Avatar
Re: 71 C10 4x2
JC Whitney used to have a lift spring in the catalog for 2x4 trucks. May want to check. I know somebody does make them. Be a giant PITA to install I'm thinking...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
