Old 01-20-2018, 04:31 PM   #1
65chevysub
65chevysub's Avatar
Inline fuel filter
I found this in a bucket of parts from a friend and was wondering if anyone else has used them and how you liked or disliked them? I'm currently using the clear plastic one but want something a little smaller and glass.
I will be putting in a 350 in a month so rounding up parts now.
Thanks for your input.
65chevysub is offline   Reply With Quote
Old 01-20-2018, 04:35 PM   #2
duallydude63
Re: Inline fuel filter
ive used them in the pass i like them ez to clean & u can c whats in your gas tank !!!
duallydude63 is offline   Reply With Quote
Old 01-20-2018, 11:08 PM   #3
raidmagic
raidmagic's Avatar
I have one on my truck right now. I kinda like it. You can take it apart and service it and you can see what's going on really easy. When I got my truck the fuel system was a mess. I've since done a new tank and all new lines so I don't have as much a need for it as I did.
raidmagic is offline   Reply With Quote
Old 01-21-2018, 12:50 AM   #4
slepysal
slepysal's Avatar
x2
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-21-2018, 08:59 AM   #5
I have seen too many crack or break. Gas on hot engine, not good. It is nice to have a see thru filter, but I use all metal filters. Just overly paranoid I guess.
Old 01-21-2018, 09:30 AM   #6
65chevysub
65chevysub's Avatar
Thanks everyone. I will use it as I like what everyone said about easy to service and see whats in our overpriced gas. I understand as well about the cracking/breaking but I think as long as I don't overtighten the ends, it should be good. I will get some replacement filters, and put it with my stash of parts.
Old 01-21-2018, 02:31 PM   #7
61K10
61K10's Avatar
I had one on my Nomad years ago and it came apart while driving. Not good. It seams the threads wore where it screws together letting it come apart. Might have been just a bad one. Won't use one again.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-21-2018, 03:06 PM   #8
geezer#99
geezer#99's Avatar
I had one crack open. I smelled gas, pulled over to see gas boiling on my intake.
It’s not the overtightening that causes it to come apart.
It’s vibration that does it.
Old 01-21-2018, 04:03 PM   #9
jayoldschool
Moderator
Glass? Never. The big plastic replaceable FRAM style goes on mine. I've used these for 25 years without an issue. You can immediately see if the fuel pump is working and if there is dirt in the line.
jayoldschool is offline   Reply With Quote
Old 01-21-2018, 04:26 PM   #10
Desert_Eagle02
The glass ones are a no go for me as well. I've heard to many bad stories about them to risk it. I've ran the plastic style ones before with no problems. But have since switched to the metal ones.
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 01-21-2018, 05:07 PM   #11
I use the plastic ones for initial engine break in or if I think I have a flow/dirt issue. Otherwise I use the metal ones.
Old 01-21-2018, 05:17 PM   #12
expedition
I agree glass one are dangerous ,the fram metal one are a lot safer ,just pop a new one every so often .
expedition is offline   Reply With Quote
Old 01-21-2018, 06:59 PM   #13
65chevysub
65chevysub's Avatar
Ok. You all have convinced me: no glass. I will stay with the plastic and/or metal.
Old 01-23-2018, 04:00 PM   #14
botoepfer
Active Member
botoepfer's Avatar
I installed this when I replaced my kinked fuel line its a Sniper
botoepfer is offline   Reply With Quote
