01-22-2018, 12:22 PM | #1 |
Heater Fan Switch
I am trying to get the interior sorted on my 1970 GMC stepside and have a question regarding the heater switch. My truck had a three position switch mounted with two unoriginal screws in the hole to the right of the controls, I believe it should have a cigarette lighter there. From my searches here I can not figure out where the switch was originally mounted. Does anyone know or have a picture of a dash with the correct setup. Thanks and sorry for the stock photos as I have everything apart and in boxes.
01-22-2018, 02:36 PM | #2 |
Old member
Re: Heater Fan Switch
I'm not sure what you are asking here. The heater control uses the 2 holes in the bottom mount to mount to the dash.
This is my 71 with AC controller but it mounts the same way as yours. Your fan switch goes on the back side and the lever operates it.
01-22-2018, 03:16 PM | #3 | |
The Older Generation
The switch mounts on the right side of the heater control unit and the arm attaches to the center slide arm.. There should be two holes in the pot metal on the frame of the unit and a hole in the center arm. LockDoc
01-22-2018, 03:30 PM | #4 |
Thanks Guys! That make sense. Andy4639 I should have stated that my truck is non-ac so it doesn't have the switch on the left side of the controls. Someone broke the middle lever and rigged a flat piece of metal in it's place. I guess that is why they screwed the lo med high switch in the lighter hole. I will have to buy a kit with the new levers and put it back to original. Thanks Again!
01-22-2018, 03:37 PM | #5 | |
No problem. The repair kit I bought had steel arms and worked out really good..... LockDoc
01-22-2018, 04:39 PM | #6 |
LocDoc Would you happen to remember where you got it?
01-22-2018, 05:20 PM | #7 | ||
Old member
https://www.classicindustries.com/sh...ater/controls/
01-22-2018, 09:34 PM | #8 |
I have a local supplier I buy my stuff from. I'm sure he got it from Here..... He gets 90% of his parts from Classic.
https://www.classicparts.com/1967-19...departments/7/ LockDoc
01-22-2018, 11:19 PM | #9 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Here ya go
01-22-2018, 11:19 PM | #10 |
Post Whore
Here are a couple photos of my crusty spare. They may help.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-23-2018, 07:08 AM | #11 |
Old member
I spent 20 minutes googling for a picture like yours. Thanks for posting. I'll save these for the next time.
