'68 disc brake conversion...
I know this horse has been beat to death already but after reading for hours im still not 100% for sure on what i need... I had rather not swap the crossmember. Im planning on going thru the front end with new parts anyways, so can i use 71-72 spindles, ball joints & tie rods and leave everything else the same? I guess i'm going to go with aftermarket 6 lug rotors so i dont have 5 on the front and 6 on the back.
Re: '68 disc brake conversion...
I'm in the same boat with you, so I'm curious to see what others suggest. If you wanted to swap stuff over from a later model truck to piece together your own setup but keep your crossmember and arms, you will have to change the tierods and balljoints as well.
On the other hand, there are plenty of aftermarket options available to keep your '68 stuff. From what I've found, the ECE kit is the most complete. It has everything you need from a new master cylinder and proportioning valve down to all components at the wheel. Of course, it is the priciest of the basic disk conversion kits. Also, as far as I can tell you can only get it from ECE and they kill you on shipping. The other popular aftermarket option is CPP, which is what I plan to do. The nice thing is you can get all their stuff through Summit for free shipping if you plan your purchases properly. The problem with their kit is it is an "at the wheel" kit, so there are several parts missing that you will need to complete it. Basically, it's missing the master cylinder, proportioning valve, and a few fittings to connect the brake lines. It also comes with flexible lines at the caliper that need to be adapted to your current hard lines. These are the things I figured I would need to complete the CPP conversion: CPP "at the wheel" conversion kit master cylinder proportioning valve with bracket and lines to master brake bleeding tool for prop valve fitting to connect rear line to prop valve correct brake hose from caliper to hard lines The only thing I'm not sure of what I need is a possible adapter to go from the front hard line to the prop valve. Keep in mind, I am still researching this like you and this is just what I've been able to gather that I need. I am fairly confident in this parts list and am ready to pull the trigger on it, but I share it here to also get some other opinions and possible corrections. I have not seen a comprehensive list of parts required for this swap so I figured we should start somewhere.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread Last edited by hewittca; 01-23-2018 at 12:47 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
There are many ways to get disc brakes,... but I suggest starting with 63-70 conversion spindles.
They come in stock height or dropped and are the same money as 71-72 or 73-87 spindles. The advantage is no need to change your tie rods, steering centerlink, or balljoints.
Here you go. Simplest and best one you can do. Puts light 3/4 ton brakes up front.
https://scarebird.com/index.php?rout...product_id=150
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#5 | |
You don't have to change out the cross member. I went with 73-87 control arms and spindles with disc brakes. everything bolted right in on my 68 except you have to get an adapting adjuster sleeve for the tie rod ends. 73 - 87 uses a larger size tie rod ends and the inner ones stay with the originals.
1968 SWB Step Side, Big Block, 4L80E , Running! |
#7 | |
Now, when it's complete, you'll have '68 spindles/tie rod/ball joints ( all your current stock components), '95 rotors/calipers/pads and proprietary caliper brackets at stock ride height. The other "easy" route is to purchase and aftermarket spindle that will accept your stock tie rod and ball joint ( 1968 stock parts ) and also use 72-78 rotor/caliper/pads. The difference between the two will come down to the price of the "kit" above + the price of the '95 rotors/calipers versus the price of the aftermarket spindle + the price of the 72-87 rotors/calipers. I'm unaware of any significant differences between the actual hardware here like for instance the diameter or thickness of the rotors. If the '95 rotors are beefier, I might be inclined to go that route. Whatever you do, document it well for future owners who may be very keen to know. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#8 | |
The BIG difference is that you know what parts they are and can buy replacement parts at autozone instead of having to buy from the supplier of the kit. AND these install heavy half ton parts 5 lug OR 6 lug. You get more than adequate braking.
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Getting ready to make the conversion on my '69 C-10 next weekend. I am using parts off a '79 C-10. Got all the moving parts so the entire front end (not including A arms and cross member) will be standard '79 parts.
I will post how the transformation goes, but I was lucky to get all the parts from a '79 cheaply. I will be installing all new tie rod ends (inner and outer), ball joints and 6 lug rotors I purchased separately.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
#10 | |
do some shopping on 73 to 87 parts, I was able to buy the front frame section with all the front end parts for just $100. Cleaned parts and replaced bushing and tie rod ends with MOOG parts or you could get the store brand. Left the 70 crossmember in place and now have a new front end.
#12 | |
#13 |
a-frames ( but could have just put on newer ball joints)
center link ( since it has larger holes for tie rods) tie rods. Spindles, idler and Pitman arms and PS gear box. and the sway bar too. My truck didnt have one or PS so I just updated the whole thing to make it al the same PHP Code:
#14 |
Just completed the brake conversion on my '69 this past weekend with great success. Took the entire steering setup out of a '79 suburban including idler arm and pitman arm. Also grabbed the '79 spindles and calipers for the brake conversion. Replaced the upper and lower ball joints in my '69 with new Moog parts for a '79. Replaced the inner and outer tie rod ends and adjusters as those parts were tired from the Suburban. Installed the 79 hubs, the rebuilt '79 linkages, installed new 6 lug rotors, used the calipers form the '79 as they were in good shape, replaced the brake lines converting the 3/16 lines to 1/4 inch and installed new flex lines using lines from a '72 to maintain the 11" length required for the '69 setup. Also installed a new brake booster and master cylinder from Summit. My front end is now tight, all brand new braking system, and the truck stops on a dime. Huge improvement from drum brakes.
