Garage Queen Material
disconnecting lockup on th350c?
i dont need or want the lockup on my tranny. the line gets in the way and i never noticed the rpm's drop before.
so can i just remove all the wiring and hoses that run it? |
Insert Witty Text Here
The vacuum hose that goes to the transmission needs to stay. You would have it with or without a lockup convertor. AFAIK, the only extra thing going to the transmission that is related to the lockup is the wiring harness. If you disconnect it, save the wiring harness in case you ever decide to put it back on. I had to buy one at the dealer and just the plug cost me $27.
I have heard both that is is okay to disconnect it and that it is not. I guess it depends on who you talk to. I have no personal experience with it. I left mine hooked up. What can it hurt? Slonaker |
My Sub has had an unhooked T350C for over 4 years with no problems.
Stylin
the wires on my plug are bare. so i guess mine never did work and its a figment of my imagination that it was ever working
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
I know if you disable the lockup on a 700R4 the tranny will burn up quick because the small lockup TC generates a ton of heat when its unlocked. I think thats how my first one died, or maybe it was the constant power braking.....
Anthony 07 Tahoe LT 70 Chevelle 450HP 383-TH400 77 GMC Royal Sierra~Resto in progress~ |
www.loweredd.com
I love my 350C!
Stylin
how would u go about hooking it back up, i know ive got a square trans filter, and i think thats only for regular th350's but, im just wondering how u would go about hooking it back up
www.loweredd.com
the filters are the same cracka
It followed me home?
Can someone explain what the lockup is, does?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
www.loweredd.com
drops the RPM's, cause it "locks up" the convertor. Then your running 1:1 I think.
lowerdd, you're absolutely right. under normal conditions there is a bit of slippage in a TC, inside a lockup TC there's actually a clutch plate that engages with the housing of the converter, eliminating the slippage and giving a true 1:1 ratio.
www.loweredd.com
Yea!! LOL. I know I get good mileage with that tranny and my 2.73:1 gears!!
