Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-23-2018, 09:26 PM   #1
IllinoisK30
Active Member
IllinoisK30's Avatar
WTB Temperature Sending Wire
Looking for a temperature sending wire for my 1977 Chevy truck with 350. The wire is green and has a plastic end on it that covers the terminal end. If you look at the pictures mine has been butt connected with a red wire and the plastic end is broke. I would like to get one as long as I can so I can make the splice inside the main harness. Plastic end needs to be intact as well. Thanks for any help.
IllinoisK30 is offline   Reply With Quote
Old 01-24-2018, 10:22 AM   #2
blindbug
Re: WTB Temperature Sending Wire
I had this wire under my hood and thought it went somewhere else, clipped it and spliced it to extend it, then when I hooked it up my temperature light was on. That's when I realized that the owner before me had unhooked it and stuck it right next to the carb, probably because he didn't remember to tag his lines when installing something. Needless to say, now I have a butt splice right next to the plastic cap that sits on the temperature sending unit! Ugh.
Not helpful to you, but thought I'd share this:
https://www.summitracing.com/parts/pco-5665pt/overview/
You could de-solder the connector and run a green cable soldered directly to the connector. For $5, it's worth a shot.
blindbug is offline   Reply With Quote
Old 01-24-2018, 10:25 AM   #3
IllinoisK30
Active Member
I feel your pain, and thanks for sharing your thoughts. I may just do that.
Old 01-24-2018, 11:06 AM   #4
gmachinz
I have the correct length wire along with the OEM asphalt sleeving and white terminal connector. I build these harnesses so if you only need that lead I can supply it from the bulkhead connector all the way to your temp sensor in the block-correct length and components. $14 shipped for ya. PM if you want it and I’ll send ya my paypal info! Its nice to keep things that this factory in appearance so there arent any worries.
gmachinz is offline   Reply With Quote
Old 01-24-2018, 11:49 AM   #5
IllinoisK30
Active Member
PM sent.
Old 01-24-2018, 01:32 PM   #6
gmachinz
All taken care of!
