Old 01-23-2018, 10:01 PM   #1
Darreola562
1971 C10 Temperature Cable
Hello,
I have ran into an issue with my recently purchased C10. I am currently going through the truck to ensure I make it a daily driver however have run into a couple issues that maybe one of you can help me out with. I'm in the process of replacing the instrument cluster and noticed that I am missing the temperature sensor and cable that goes to the gauge. Unfortunately, I can't find the part number or been able to find it locally (cable). Does anyone have a suggestion on how to aquire this cable?
Any suggestions would be greatly appreciated.
Thanks!
Darreola562 is offline   Reply With Quote
Old 01-23-2018, 10:29 PM   #2
rockyrivermark
Re: 1971 C10 Temperature Cable
If it's a stock sensor and gauge I believe its a wire and not a mechanical cable
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 01-23-2018, 10:32 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by Darreola562 View Post
Hello,
Thanks!
What cluster does it have in it, gauges or warning lights? The temp sender wire would be a 20ga dark green wire. It should come out of the firewall connector and run along the valve cover by the intake or along the oil pan under the drivers side exhaust manifold depending on what engine and year truck you have.
LockDoc
Leon
Old 01-23-2018, 11:24 PM   #4
Darreola562
LockDoc
It has the gauges that includes the temperature speedometer battery voltage etc...the entire gauge is missing for the engine temperature along with the green cable and the sensor. I’m having a real time finding anyone that carry’s it.
Old 01-23-2018, 11:57 PM   #5
Curtb1971
Curtb1971's Avatar
Welcome to the forum! Hmm, what year and engine is your truck? Is there still a plastic circuit board on the back of your gauge cluster? If you can try to get a picture of the back of your gauge cluster and your engine compartment they can tell us a lot more of what you have going on. Curt
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 01-24-2018, 12:43 AM   #6
LockDoc
LockDoc's Avatar
What engine do you have?
Rock Auto has the senders.
http://www.rockauto.com/en/catalog/c...+/+sensor,4748
You need the one with the single brass post on top.
I can see how someone might remove the green wire from the engine compartment, and I can see how someone might remove the gauge, but I doubt they would remove the green wire from under the dash because they would have to unwrap the wire loom to remove it.
LockDoc
Leon
Old 01-24-2018, 01:02 AM   #7
dmjlambert
dmjlambert's Avatar
The wire with connectors:
https://www.lectriclimited.com/tempe...pair-kit-88624
The sensor:
It has been discussed before on other threads you can only use the stock 1/2" NPT threaded sender for the temp gauge if you have a stock gauge instrument cluster. There is no 3/8" NPT sender that will work. If you have a 3/8" NPT threaded hole in the engine head, you can get a 1/2" sender and have a machinist turn and thread it to 3/8". I had forum member A1971Blazer turn and thread mine. Other people had it done by brian mac. I used GM part number 12334869, AC Delco number G1852. This only applies if you are outfitting your truck with a stock gauge instrument cluster, if you've got something aftermarket then disregard.
Welcome to the forum. We love to see pictures uploaded to your posts. Show us what you've got.
dmjlambert is offline   Reply With Quote
Old 01-24-2018, 04:43 AM   #8
stsalvage
Scrapper 1
stsalvage's Avatar
your looking for this wire harness w2ith this wire and this sending unit.Depending on what intake you have an what engine you have.
I like the 1967 water outlet for the 327 with come straight out and they make a hose for it but don't have the number right now but will post it to help you out.But i use this same set up for my 1972 350 and i can run this same sending unit on top of the driver side intake manifold and its a plug and play system.Here look
Now i show the water sending unit on the side of the head not a good place for that sending unit cus the wire fries an never seems to last.I like it on top of the intake manifold where the ware and wire connector can't burn up.if you run headers its never a good spot to run that sending unit next to them
stsalvage is offline   Reply With Quote
