1969 disc brake swap
Going to swap to front disc on my 69 but want to use stock spindles. Does anyone know of a kit or what years newer truck I can scrounge parts off of. Thanks
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
#2 | |
The Older Generation
Re: 1969 disc brake swap
Find your configuration in this post, click on it and read up on it.... http://67-72chevytrucks.com/vboard/s...d.php?t=444823 LockDoc
Thanks for the info. One auestion are the years listed together compatible
#4 | |
Yes, I believe they are. LockDoc
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
http://67-72chevytrucks.com/vboard/s...isc+brake+swap
Be sure to check the linked thread in the first paragraph of the thread I linked you to.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Scrapper 1
I just took a 1969 1/2 ton apart and put my 1971 spindles on an put new ball joints in and upper and lower bushing and it bolted right up.I never could under stand why people swap out the whole front end.
I just bought some CCP spindles for my 1968 longhorn asked the guys at CCP if they make a 1/2 ton spindle that could use the 3/4 ton ball joint they said yes they do.CCP said if they did not you could put a reamer in there and make it work for the 3/4 in Ball joint.Never could under stand why mess with your front A frame just to get front disc brakes. You know my ex boss use to Race Baha 1000 in a 1979 chevy truck he used Race 3/4 or 1 ton front upper and lower ball joints cus they can take the punish ment.never have to worry about busting a 3/4 inch ball joint in a 1/2 ton truck.Only way is have a front end collision.You will never brake a 3/4 or 1 ton ball joint in a 1/2 ton set up |
