Old 01-24-2018, 08:03 AM   #1
mi396ss
Windshield Lower Corners
Does anybody make replacement patch panels for the lower corners of the windshield? Mine are rusting pretty badly and need to be replaced. Any information is appreciated.
mi396ss is offline   Reply With Quote
Old 01-24-2018, 10:29 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Windshield Lower Corners
I haven't seen any repair pieces for them.
I don't know how bad yours are or what your skill level is but I just made the pieces for mine.
LockDoc
Leon
Old 01-25-2018, 06:41 PM   #3
mi396ss
My rust is very similar. What did you use to fix those? They look great.
Old 01-25-2018, 09:10 PM   #4
muley
muley's Avatar
Mine leaks on the drivers side. I'm confident when the windshield is out the metal will look similar. I read on here somewhere that there are drain holes under the windshield. Is this right? Or are they under the cowl?
When it rains hard, mine leaks behind the dash onto the floor. It appears to be the original windshield and rubber. The rubber outside is hard as a rock. I just don't want to plug holes that need to be open.
Grandpa 1953 M38A1 Jeep
1989 GMC K2500
1958 Alaskan Camper all original
WORK : A necessary evil that finances
what I really like to do.
muley is offline   Reply With Quote
Old 01-25-2018, 11:28 PM   #5
LockDoc
LockDoc's Avatar
I just cut pieces from some scrap metal I had and welded them in. Don't use regular bondo to finish them off, use a product like Metal to Metal.
https://www.oreillyauto.com/detail/e...er/889/4299769
If you look in the corners of the dash on the inside, by the windshield, you will see the drain holes. Your leak will probably be where the body panels are welded together under the windshield gasket though.
LockDoc
Leon
