Old 01-24-2018, 10:02 AM   #1
brown7373
brown7373's Avatar
Finishing my crate engine questions
The literature says I need a (left) side oil dipstick tube, and gives a Chevrolet Performance number (03876870), but when I plug it in at any Chevy site I get nothing. Any reason not to buy from Classic?
Is the oil filter adapter removable from my old 350, or is it cast into the block?
brown7373 is offline   Reply With Quote
Old 01-24-2018, 10:06 AM   #2
PTC002
Re: Finishing my crate engine questions
Any dipstick tube will work....most come with a dipstick. I did not want a chrome one and it took me awhile to find one that was not chrome. I also kept the original dipstick as I did not like the cheap appearance of the new one. The oil filter adapter should unbolt from the old block.
PTC002 is offline   Reply With Quote
Old 01-24-2018, 10:20 AM   #3
Grumpy old man
Grumpy old man's Avatar
This should help
https://www.ebay.com/itm/SBC-Black-S...!US!-1&vxp=mtr
Grumpy old man is offline   Reply With Quote
Old 01-24-2018, 11:37 AM   #4
brown7373
brown7373's Avatar
I don't want chrome either. The confusion comes from the paperwork from Chevrolet Performance that shows different parts and numbers for right side or left side dipsticks. I will see if I can remove the original as well as the oil filter adapter. Thanks
Old 01-24-2018, 11:47 AM   #5
Grumpy old man
Did you click the ebay ad? for a black steel dipstick $9.95 shipped is cheeeeeeap
Old 01-24-2018, 01:16 PM   #6
brown7373
brown7373's Avatar
Yes, I saw the ebay ad and I may get that.
Old 01-24-2018, 01:20 PM   #7
demian5
demian5's Avatar
http://www.truckandcarshop.com
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-24-2018, 09:38 PM   #8
El Dorado Jim
the steel plug that comes with your crate engine to plug the hole you arent going to use i found to be useless, i took a bolt the right size cut off the threads so that i had about an inch of smooth bolt with the head on it and then used gasket sealer on it and put it in the hole on the passenger side, no way it can fall down into the engine...
El Dorado Jim is offline   Reply With Quote
