Old 01-24-2018, 11:03 PM   #1
chevy49
chevy49's Avatar
step notch
how tall do I need the step notch in a 65 c10 fleet side short bed to clear 20 inch wheels with a 29 inch tire? I am trying to keep as much bed depth as possible thanks
chevy49 is offline   Reply With Quote
Old 01-24-2018, 11:26 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: step notch
???? a step notch to clear wheels ???? unless im wrong, a step notch is in the frame for lowering a vehicle to clear the axle not a wheel
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-25-2018, 10:51 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: step notch
While the wheels and tires really don't determine the height of the frame notch, it really is a matter of how low you want the rear of the truck and the location of the rearend housing in relation to the frame.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-25-2018, 02:33 PM   #4
Lobotie
Lobotie's Avatar
Re: step notch
The way I've done is measure the distance from the ground and bottom of the frame (in front of the rear wheels just before the frame starts to go up) then transfer that distance to the top of the axle. Presuming that you want to lay frame.
Lobotie is offline   Reply With Quote
Old 01-25-2018, 10:53 PM   #5
chevy49
chevy49's Avatar
