New engine for 94 Silverado
My older brother owns a 94 Silverado that is rust free but he’s having issues with the engine. It’s a pooch anyway and he’d like to replace it with something with more hp and torque. It’s a 5.7 TBI engine so he wants something that will bolt right in and mount up to the existing trans. Where’s the best place to pick up a replacement engine with 300+ hp?
1972 C10 Custom Deluxe 4.8 LS 4l60e |
driving is in my blood
Re: New engine for 94 Silverado
A stock engine with a decent cam and headers will be 300hp.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Nothing is going to drop in with 300hp and stock TBI unless he carbs it. You'll need an engine that's designed to put out 300+, a chip, and probably a new regulator spring and fuel pump.
The closest you'll find is the 383 that GM makes as a TBI replacement, but I believe that still needs at least a chip.
Mike |
Agreed. Closest thing is a L31 vortec long block. Around $1,900 and best info is 255 hp. There were versions rated up to 330hp from what I read but not this one.
But to put it in the a TBI truck is not just a bolt in. Well the engine will bolt in but you have to have different intake manifold to fit the heads, plate for the TBI and you will HAVE to have a new tune on the computer to make it work. I am going to buy one for mine and possibly swap out the cam. But this is not going to be a bolt in swap. It is going to take some tuning to make it all work together. |
Thanks for the replies!
I talked with a tech from Scoggin Dickey and he thought my brother could go to the L31 Vortec which has 250hp and 330tq. He would have to purchase a manifold that would accept his existing original TBI. Headers might add a few more hp. The current motor I believe is 195 so it would be an upgrade. I think he should go with a 383 and add a Holley or Edelbrock FI system.
1972 C10 Custom Deluxe 4.8 LS 4l60e Last edited by 72LSLB; 01-26-2018 at 08:21 PM. |
I put a set of headers on a truck I had 20 years ago. Was a 90, 350 with a 154k miles if not more. Only thing I did was put headers on and get rid of the cat, and was like a totally different truck. Felt like the torque was doubled. Think they were Flowtech's.
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
I have a 95 C1500 with 323k on the original TBI motor. I have headers, AirAid intake, MSI coil, and full stainless high flow exhaust. It made a huge difference in the TBI 350.
I also did the L31 conversion on my 95 Yukon using a crate motor, the TBI to Vortec manifold, fuel pump, spring, chip, etc. I have the same external setup of headers, MSI coil, intake, etc. on it as I do the truck. It's a considerable increase in power and although I had to fabricate some items and figure out a few things that are a tad different, it was well worth the investment in time and money.
Mike |
Glad to hear someone confirm what I knew... well, hoped I knew. My 93 has a loose rod bearing, knocks before oil pressure comes up. Hoping to swap it out this spring. Was driving home today thinking about the swap and how it wouldn't take much for the swap to gain 100 hp over the stock Suburban engine.
#9 | |
#10 | |
Brian
I can post it here for anyone else who might need it:
-GM TBI to Vortec manifold 12486572 -Driver's side exhaust manifold or headers with EGR tube. I'm went with Gibson GP102S (if you care about EGR) -EGR tube for Vortec 10242876 (Dorman 598-200) (if you care about EGR) -Chip kit from tbichips.com - pcm chip, 18psi spring, fuel pump -Intake bolts (8) - 12550027 -Intake gaskets - MS901312 -Dizzy with melodized cam gear - https://www.summitracing.com/oh/part...0200/overview/ -Dorman 46001 PCV tube -3/8 npt to 1/2" nipple right angle - This was for the brake vacuum tube -Vent tube to tbi from valve cover -5/8 nipple to 1/2npt - for coolant. I think I used 2. Other notes: I had to modify the MAP sensor and throttle cable/cruise brackets for the new manifold bolt pattern. IIRC, the MAP bracket just needed to be bent a little, and the throttle bracket needed to be bent over the other way, trimmed, and a new hole for the intake bolt drilled, then painted. All of the accessories bolted right up, no issue there. For the coolant hoses, I ran a hose from the rear outlet to the water pump, the front outlet (on top) to the heater core, and the heater core out to the radiator just below the fill. My temp sender is in the front of the manifold. It's not a bad swap, just lay everything out ahead of time especially the brackets. Get some from the junkyard or eBay if you can. If I think of anything else, I'll post it here. Good luck!
Mike |
If he decided to stay with the original TBI engine would those same Gibson headers work?
We don’t get emission tested here so EGR stuff could probably get yanked unless it throws a code. Can egr stuff get turned off with a tune like LS computer tunes can?
#13 |
You could use this Gibson headers, but then gonna have a hole where the EGR tube would go. just get the headers for the year of the truck. Mine went on in the driveway laying on the ground. I put a piece of 3" pipe in place of the cat, everything went on fine and bolted right up. Made it louder and gave it a lot more power.
#14 |
Gibson shorty SS headers without EGR are the GP100S. Your choice though, I have Edelbrock shorty SS on my truck and the Gibson SS on my Yukon. They really look like they were made by the same company. The only difference is the EGR tube on the Gibson, and the Gibson have the built in donut which I really like.
Mike |
#15 |
Mike,
Trying to find a price on the 12486572 manifold but Google keeps coming up with a 12496821 manifold. Was the 572 replaced with the 821 at some point?
#16 |
Same part, different numbers. They are the same manifold from what I can tell. Probably a plant shift or something like that.
One other thing I remembered is you'll need a 3/4" plug for the timing cover. The Vortec uses a crank sensor that bolts in there, but you won't need it. Plug the hole otherwise oil will get out. I used some RTV and tapped it in with a long socket.
Mike |
#17 | |
#18 |
I had a hard time finding the right size gear that fit my distributor shaft, so I just went with a whole new dizzy.
Mike |
#19 |
Its the oem gear for vortec small blocks, fits any standerd distributor. I've used them on several 70-80's models, perhaps TBI's are different some how?
#20 |
Everything that Summit carried was either too small or too big for the distributor I had. Now I had an aftermarket one already so maybe that's why. Either way, I was unsure of the overall condition of the old distributor so a full replacement was in order anyway.
Mike |
#21 |
How much does he want to spend?
From what I'm reading here, the price is going to be high. I had my '95 2500/5spd, block crack not long ago and long story short, NEEDED a motor for my daily "quick". All I had built up at the time is a '62 283 (forged .060 over), Comp xe268 cam with some self ported 062 Vortec heads, Ebay Vortec spread bore intake. TBI adapter and the rest of the accessories and Flow-tech afterburner headers modded to true dual exhaust, with 30+" glass packs EVERYONE said it wouldn't work, but the only issue was it ran pig rich on idle. and got around 16-17 HWY mpg! and sounds MEAN! (3.42 14 bolt, 285 tires, so it's right at @2000rpms going 70. AND 6000lbs with me, and would've eaten the orig 350's lunch) And all in for about $700-$900.00 and my time. (almost a week) Brian from TBI-chips said that he would need the truck to work out the fuel maps and that in itself wouldn't be cost effective. (actually he wouldn't touch it) Thought about going with 4.3 V6 injectors/747 ECU but would rather have it rich than LEAN driving So, I drove it for almost a year, changing the oil sooner because of fuel condition. Now have installed a Rochester and a china HEI (just 'zip-tied' the wiring off to the side) and now it's leaner at idle but dropped to about 14mpg and now almost 1.5yrs. Waiting to get my CR-v running so I can install my '80 406 for it for a lot more torque. (swapping the top end parts) The TBI years is a great platform to swap stuff into. Because it's CHEAP CHEAP, and parts are only a search on Craigs list or Pull-it away.. Heck, you could even do a Big Block Caddy and still use the TBI and your trans!! BUT, where I am, I don't have to worry about Liberals forcing folks to purchase NEW just to pass emissions. E Last edited by rockosocko; 01-30-2018 at 01:27 PM. |
#22 | |
You can always find negativity on the internet but I have seen enough I am afraid to try him. Several stories of being in 5 or 6 chips from him and their car/truck still not running right. Many saying they couldn't see any improvement from chip to chip. A couple where the people sold the vehicle and gave up. |
#23 |
If you're asking me.. I brought this to his attention and he pretty much said that
"some people follow directions, and some don't. And expect PERFECT RESULTS.." It took a couple calls/emails, but finally got to actually speak to him for a while and by me also having a side business of offering a service to the public, could see where he's coming from. He was polite to me, but basically told me that my combination of parts would take a long time and LOTS of cash to figure it out, and then might not be all that happy with results. If you're going pretty much "STOCK", I think he would be able to suit you. But like anything that requires and ingredient list, the more you add, the worse it can get in a hurry. And can send you down rabbit holes that are going to get expensive. Just keep it simple. Cold/ram air/ Header(s) are usually the first 'changes' people make. A GOOD close friend used him and it took a couple chips, but ended up totally happy and suggested to me to do the same. (it's just I'm more hard headed and can't leave well enough alone) BUT... What are you starting with? A P.O.S from C/L, or a vehicle that you know/have history/service knowledge since new? TOTALLY stock or NO? (then, what parts aren't?) ALL sensors and ECU playing nice together? ALL vacuum lines in good shape? Good Grounds and wiring not all chewed up by ___? (DAMN idiots that install car alarms are one major culprit of electrical gremlins) How many miles/years on _____ etc.. (sure it might be a low mileage, mint vehicle that sat in a air conditioned warehouse. but if the fuel lines/system are all gummed up well..) Remember, they're pushing 30+yrs old. AND, even fuel ratings can play a part. Gotta jet. e |
#24 | |
Mike |
#25 |
Good to hear Mike.
rockosocko, I have no experience so of course I don't know. But have read on another tuning forum of two people that had paid for 5 or 6 chips from him and gave up. They used one of two guys on the forum and first or second chip and they basically say it was like Night and Day the difference in the vehicle. Lot of similar stories. I run a small business and have worked with the public so I know how hard some people are to please so I take things like this with a grain of salt. But I keep reading it over and over and that is when I start to think there is at least some truth to it. |
| Bookmarks |
