Old 01-26-2018, 12:00 AM   #1
Bargy1
Horn or Horns
I have a 1965 C10 that I am closing in on finishing with a 7 year frame off restoration. When I got the truck it had two horns. One horn bolted to the top square tube of the radiator support and the other horn bolted to the sheetmetal below on the radiator support. The second horn that was bolted to the sheetmetal appeared to be scabbed in. My question is did these trucks come with two horns or one the second one added?
Thanks in advance for the help.
Bargy1 is offline   Reply With Quote
Old 01-26-2018, 11:34 AM   #2
60-66
60-66's Avatar
Re: Horn or Horns
Without seeing it , Im going to say it was the "High Note Horn" , . it was a GM Accessory offered for these trucks. Should have an H cast into it. It will also have a large square washer that the screw threads into and a green extension wire, if original. That is the original location also.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
