Old 01-26-2018, 04:24 PM   #1
Mts67C10K20
Mts67C10K20's Avatar
67 k20 brake line frustration
Good day all
I am currently getting ready to swap out my axles for a set of 1976 d44 and a corp 14 .
The problem I am having is locating a set of pre bent stainless lines for a 67 k20 w/power brakes either stock or setup for the disks
The rear axle lines I have found for the corp 14 but nothing for the front
Any info on vendors would be appreciated
Thanks in advance
Fyi stock height
Mts67C10K20 is offline   Reply With Quote
Old 01-26-2018, 04:45 PM   #2
B. W.
B. W.'s Avatar
Re: 67 k20 brake line frustration
You could use lines for a 71 or 72 with factory disc brakes, should drop right in. I'm not sure if the front brake hoses are in the same location on the frame so that may require some mods.
I purchased a complete set of lines from Inline tube, the front lines were the only ones that fit properly. (FWIW)
B. W. is offline   Reply With Quote
Old 01-26-2018, 05:31 PM   #3
Mts67C10K20
Did you order the 2wd front set I did not see one for a 3/4 4wd
Old 01-26-2018, 05:55 PM   #4
Doug's68SS
Get on the phone and give them a call, they seem to have all the lines you would ever need.
Doug's68SS is offline   Reply With Quote
Old 01-26-2018, 10:38 PM   #5
B. W.
B. W.'s Avatar
I ordered P/N CTB7144 (fitment for 71 3/4 ton, power disc brakes, 4x4, long bed)
Old 01-27-2018, 04:16 PM   #6
Mts67C10K20
BW
Thank you for your assistance an information
Since Inline and the other vendors of brake lines that i called
do not offer a set for a 67 K20 and are reluctant to suggest a different set not specific
To an application
Your help was exactly what was needed
Everyone I've delt with on this board rocks
68ss thanks for the Texas insight
Old 01-27-2018, 05:07 PM   #7
B. W.
B. W.'s Avatar
Your welcome. Your right, great members & great moderators here! Keep us posted with pics please.
Old 02-06-2018, 09:47 AM   #8
Mts67C10K20
I have all the parts collected including new brake lines
So here we go
A few picks from beginning to now in process
