Old 01-27-2018, 06:18 AM   #1
jojomiamia
Wheel bearing replacement
Hi guys,
I would like to replace my wheel bearings and buy them on rockauto.
But too many pieces, I just don’t which one fits.
I own a 1972 super camper cheyenne with dana 60, if one of you has already bought bearings and can tell which ones are good, it will help a lot.
Thanks and have a great day
jojomiamia is offline   Reply With Quote
Old 01-27-2018, 11:15 AM   #2
chefk85
chefk85's Avatar
Re: Wheel bearing replacement
I would buy them at the local parts store personally and ask for Spicer bearings. Napa found mine pretty quickly and haven't had a problem for the past 2 years. I believe I went with Spicer per a board members reccomendation because they are usa made and original to your unit.
http://67-72chevytrucks.com/vboard/s...25#post7532025
71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress.
79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos.
93 Burb K1500. 350/4l60e Parting out.
2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles!
chefk85 is offline   Reply With Quote
Old 01-27-2018, 11:55 AM   #3
jojomiamia
Ok thanks,
I’ll try with Napa next time I’ll visit US or try to find Spicer bearings on the net.
Old 01-27-2018, 12:21 PM   #4
jocko
jocko's Avatar
Anyone know if Federal Mogul wheel bearings and seals are still US made? They are under the "National" wheel bearing parts group, but made by Fed Mog. Their HQ is still in the US, but they have major hubs in China and Mexico.... Just wondering if an old reliable standard is or isn't as good as it used to be.
EDIT: I did find a little more - they have manufacturing sites in 14 countries, US included. The biggest mfgrs are:
US - 5 cities
China - 3 cities
South Africa - 3 cities
Mexico - 6 cities
So, I think my answer (to myself) would be, I just don't know if I'm getting the same quality part I would have gotten in 1972. Maybe.
So, yeah, I'd try to get spice or US parts when it comes to this kind of stuff. I've been frustrated with replacement wear/consumable parts on my newer truck (2001) and the low quality. My first pitman arm from the factory lasted about 15 years. Same for ball joints. The next 3 of each haven't...
Old 01-27-2018, 12:44 PM   #5
harpo231
harpo231's Avatar
their bearings are made in south Africa
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 01-27-2018, 12:53 PM   #6
B. W.
B. W.'s Avatar
Some part numbers to help you out:
'71 GMC D60, 4x4
inner bearing Timken 28678
inner race Timken 28622
outer bearing Timken 18690
outer race Timken 18620
all made in USA
B. W. is offline   Reply With Quote
Old 01-27-2018, 12:57 PM   #7
jojomiamia
Thanks, going for this brand
Old 12-15-2021, 09:05 PM   #8
Furno68C20
Furno68C20 is offline   Reply With Quote
Old 12-15-2021, 10:44 PM   #9
Accelo
Accelo's Avatar
These are fairly expensive bearings as far as automotive bearing go.
However this guy has two Timken for Appx $12 each.
https://www.ebay.com/itm/39375876584...YAAOSwt11hhYu9
You can find most of them on Ebay. Many are older USA made.
They purchase spares and they sit on the shelf till the company is closed down and moved to China. /s
Accelo is offline   Reply With Quote
Old 12-18-2021, 12:27 PM   #10
tdangle
tdangle's Avatar
Don't forget new seals also. You may also need new races for the bearings. It's a job driving out and back in the new races. Do yourself a favor and pick up a bearing race driver set, either a loan tool or buy it. Watch a couple of videos on YouTube. I ended up grinding down a old race to use as a driver for the new ones
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 12-18-2021, 01:13 PM   #11
Joyridin
Last time I bought Timken bearings for my car, there was a note on the inside of the box stating the bearings were made in China. The box said Made in USA. Needless to say, they went back.
Joyridin is offline   Reply With Quote
Old 12-18-2021, 01:30 PM   #12
Accelo
Accelo's Avatar
What works really slick for removing races is an air hammer and a round tip/bit. You hit one side and the bearing shoots out of there. All logic says it will cock in the bore and you will have a mess. Just doesn't work out that way. Give it a try. It's amazing.
