01-27-2018, 03:26 PM | #1 |
66 c10 Rear Disc Brake Help
Installing POL rear disc brake conversion.
This is passenger side Is this correct? How does the brake hose with hose clamp attach to rear axle housing? Is the caliper suppose to sit low like this or do i need to rotate upwards? Grr! |
01-27-2018, 03:28 PM | #2 |
Re: 66 c10 Rear Disc Brake Help
Running inline tube lines too.
I have no idea how the rear lines run. |
01-27-2018, 05:04 PM | #3 |
Moderator
Mine look like this (drivers side) -
01-27-2018, 05:17 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
I think you have the caliper bracket on wrong side or ? Should be top rear area...
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-27-2018, 05:53 PM | #5 |
Thought so
Thanks |
01-27-2018, 05:54 PM | #6 |
01-29-2018, 05:45 PM | #7 |
Never Ending Projects
On the couple disc conversions I have done, I welded tabs to the axle housing.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-30-2018, 11:14 AM | #8 |
Hey all, I'm fairly new to updating these trucks, so forgive me if I say something completely "green". My first resto type project.
Fixing up a 66 C10, and am looking at doing a disc conversion all the way around, but am curious if the newer model spindles and disc brake plates will mount up in place of the originals. |
01-30-2018, 04:26 PM | #9 |
Junior Member
The Rocknrod, can you post a picture of your E brake cable from the inside?
1964 Chevy Suburban 4x4 1966 GMC Suburban 4x4 |
01-30-2018, 04:39 PM | #10 |
Moderator
Here you go:
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 01-30-2018 at 04:54 PM. |
01-30-2018, 06:58 PM | #11 |
Junior Member
Thank you sir
